EGR Valve Blew Up - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
EGR Valve Blew Up
Old 01-10-2011, 10:48 AM
meikotora meikotora is offline
meikotora is starting off with a positive reputation.
EGR Valve Blew Up
Hi anyone know what would cause an EGR Valve to blow up in a 2003 Escape?
Old 01-10-2011, 05:27 PM
I am also getting the 301, 303, 306 and 316 codes which are all misfire codes, the last one being a misfire in the first 1000 revolutions. Was getting random misfire code. Replaced cat, plugs, muffler and upper intake gaskets... 2nd blown egr valve still running poorly and no power with those codes now. it all started after sitting during severe rainstorm and went away then came a month later after another rainstorm... any ideas?
Old 01-10-2011, 09:53 PM
tonyford tonyford is offline
tonyford is starting off with a positive reputation.
The most common cause of misfires is a bad coil pack or packs. Damp, rainy, humid weather intensifies the misfires as the condensation makes the shorting out worse.
When the engine misfires, raw fuel gets dumped into the catalytic converter, if enough raw gas get into the converter it can permanetly destroy it.
A possibility is that some of this raw gas worked it its way up into your EGR valve and ignited somehow. Lucky the vehicle did not catch fire.
Any misfires that are intensified when it rains or when it gets really humid is usually the fault of a bad coil pack or packs. In rare occasions bad ignition wires or a cracked spark plug can also cause misfires also.
non EGR headers With EGR? TheGageinator 1987 - 1996 F150 & Larger F-Series Trucks 1 01-30-2014 06:09 PM
Warming up with egr delete? grantpage 6.0L Power Stroke Diesel 15 10-10-2011 09:06 PM
92 explorer egr valve? strokethis04 Explorer, Sport Trac, Mountaineer & Aviator 1 01-04-2011 02:46 PM
EGR valve sensor Volvo92906 1987 - 1996 F150 & Larger F-Series Trucks 36 07-28-2009 01:37 PM
EGR valve position sensor JCastellaw 1987 - 1996 F150 & Larger F-Series Trucks 7 01-16-2004 12:35 PM
Tags
1996, 2001, 2003, blew, blow, blown, egr, escape, explorer, ford, gas, mazda, misfire, rain, random, raw, tribute, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
