Whare to buy 48-52 inside door latches
Hello People, I am getting fustrated here in grande cache, alberta canada I can not find inside doorlatches anywhare for my truck. I have one on the drivers door but i want it to lock so i found a door that is off of a 52 that has a hole for the locks. So i bought a two lock/key set and have not found a vendor so i can buy latches any help please, Also i did ring dennis carpenter and lmc truck they said they dont make such a thing for the F-1 s thanks sean conroy
You won't find them in reproduction. You'll either need to find NOS or used. Did you try asking the person who sold you the door if they have the latch? They're rare to find by themselves. Locks on the driver's side were introduced in 1951 in the 5 Star Deluxe package.
I have a few good used ones with the lock on the driver's side. PM sent.
Also, now your driver's door is different on the inside than your passenger door. The 52 door is from a 5 Star Deluxe truck and has the frame around the bottom for the interior door trim panel, a bracket for the arm rest, and another "hook" type strip towards the top for the upper inner door trim panel. If you remove the arm rest bracket, you'll end up with two holes going through your door where the arm rest would be bolted in.
It would have been easier to find the locking latch and drill a new hole in your existing door by using the measurments from your passenger door.
Here is an ebay listing, I think this is what you're looking for. Kevin
1948 1949 1950 1951 1952 Ford Truck door latches f1 50s - eBay (item 160530130527 end time Jan-16-11 15:52:01 PST)
Those are the regular latches, driver's side and passenger side. The one with the extra flange at bottom is for the lock cylinder on the passenger side. The other one, without the extra flange, is for the driver's side without the lock cylinder.
He's looking for the driver's side with the lock cylinder, as well as the passenger side.
Looks like I'll be digging through my parts boxes to find a pair to put on eBay.
I've been looking at these;
Door Latch Control - RH - 48-52 F1 F2 Door Latch | AMD 535-4548-R
I need both doors, right now driver's side won't open and passenger side won't close. I haven't ordered them yet so I don't know what the quality is.
