I cut 8 In out of the center behind the cab then the rest off the back . moved rear cross member forward
I assume you mean that you are using a 6 foot bed and not trying to make a 6 foot bed out of an 8 foot bed...that doesn't work very well. On the frame take 12 inches off the back. I used the extra crossmember for upper shock mounts. When cutting out the 8 inches start just rearward of the bed mounting hole about 1/2 to 1 inch and you might not have to redrill the bed mounting holes....
Why would you want to do that? As stated previously in this 8 1/2 year old thread, the 8 foot box is taller, wider, and longer so a 6 foot bed would fit horribly in place of an 8 foot since it would be shorter, narrower, and not as tall.
