1981 f-150 manual door locks - Ford Truck Enthusiasts Forums
Old 01-09-2011, 09:56 PM
1981f15085607 1981f15085607 is offline
1981f15085607 is starting off with a positive reputation.
Smile 1981 f-150 manual door locks
new to the forum...does anyone know where i can get manual door locks for my f-150...help......!!!!
Old 01-09-2011, 10:51 PM
campotter221 campotter221 is offline
campotter221 is starting off with a positive reputation.
the junk yard is a great place to look
Old 01-10-2011, 12:09 AM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Do you have those weird ones that slide on the door panel? If so, a popular thing to do is get the later setup and convert it over to the ones with the pin that sticks up. I believe that was a 1 or 2 year only lock system, and they all broke.
Old 05-09-2011, 07:50 PM
pfcjs pfcjs is offline
pfcjs is starting off with a positive reputation.
Quote:
Is this easy to do?
Any write ups anywhere on this?
Thanks...
Old 05-09-2011, 09:32 PM
1980 Ford F-250's Avatar
1980 Ford F-250 1980 Ford F-250 is offline
1980 Ford F-250 is starting off with a positive reputation.
I am also curious. Is this an easy thing to do?
Old 05-09-2011, 09:42 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I, too, am interested in doing this. My father's '81 has those locks and I have 2 doors put back w/the later locks on them just for that purpose. I'm sure I can figure it out, but a how-to would be appreciated.
Old 05-09-2011, 10:23 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
Are you guys referencing the ones that stick into the door panel? Usually silver in color, or something else that I haven't seen? If its the silver ones I have a write up that I am working on for some custom mods.
Old 05-09-2011, 10:26 PM
Gary Lewis's Avatar
Silver ones are what we want to go to, the ones used in '82 and later.
Old 05-09-2011, 10:30 PM
Oh ok, I appreciate your post!
Old 05-09-2011, 10:34 PM
Gary Lewis's Avatar
A how-to will be most welcome! Thanks, Glove.
Old 05-10-2011, 08:14 AM
80FlareSide's Avatar
80FlareSide 80FlareSide is offline
80FlareSide is starting off with a positive reputation.
The slide locks were introduced in 1980 with the re-design. Since there is apparently no amount of silicone spray or lithium grease that will keep them operating properly (personal experience) they were phased out in about 1981 1/2. Those of us that are unfortunate enough to have them are stuck between keeping the truck "correct" or having working door locks.
I have given up all together on locking my truck. Its a 50/50 chance the doors will unlock, and if someone really wanted in, that window is only a brick away from being open. Not to mention the fact that a 3 y/o can get the thing running with a slide hammer and screwdriver. If it ever gets stolen I figure I will just catch them at the next gas station.
All kidding aside, it is an easy swap that I plan to undertake in the future. You can either buy the parts at a j/y, or online (easiest to to probably take the entire mechanism from a donor door rather than trying to aquire exactly the right parts). First you will need new (or j/y) door panels to locate and drill a hole for the lock push button. Off hand I cannot remember if the latch mechanism itself can be re-used. From there is is a matter of switching over the linkage from old to new.
Old 05-10-2011, 08:58 AM
Franklin2's Avatar
I have heard people talking about it, but never have done it myself. My 80 did have the lousy door locks though, so I know what that's all about. Looking at it but never having actually done it, I would think the hardest part would be drilling the hole in the top of the door.
Old 05-10-2011, 09:08 AM
Gary Lewis's Avatar
As said, Dad's truck, the next one I plan to restore, has the slide locks and they don't work. So, the '82 parts truck I have will provide the bits and pieces - whatever they are. I'm just hoping Ford saw fit to use the same attachment points.
Old 05-10-2011, 12:30 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Slide Locks Were used on 1980-1981 to a build date of 12/80.
1981 from a build date of 12/80 to 3/81 used a black hexagon shaped **** for the door lock rod that sticks out the top of the panel.
1981-1986 from a build date of 3/81 uses a chrome lock **** for the door lock rod that sticks out the top of the panel.
If you have a 1980 or 1981 with slide locks, you will have to drill a hole in the doors and get seperate door panels to do the swap. You will also need the lock rod that goes from the door lock to the top of the panel. On the 1980 you will need a new door lock tumbler as well, or at least according to the book.
My slide locks on my 1981 work quite well. I like them. However, if you ever remove your door panels, you have to remove the slide lock from the panel first, or you will bend the rod. Even slightly bent the locks wont work right. This is the main reason why they fail or stick.
Old 05-10-2011, 02:51 PM
bob_351 bob_351 is offline
bob_351 is starting off with a positive reputation.
i just bought the whole latching assembly that goes inside the door but you might just need the rod i can check later. then just drill a hole in the top of the door panel or buy junkyard replacement panels
1981 Ford F150 Shawna Valadez New Member Introductions 1 11-15-2016 11:09 AM
1980-1981(?) NOS slider lock control 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 06-07-2016 02:48 PM
info on a rare 1981 ford f150 truck... sweetjoey45 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 04-06-2016 09:09 AM
Help with Power Windows and Power Locks Harness jrf81 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 01-27-2015 10:22 AM
87-91 or 92-96 Door panels on an '81? TheKirbyMan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-19-2010 06:03 PM
Tags
150, 1980, 1981, 81, actuator, autolock, door, f, f150, ford, image, lock, locks, manual, power, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
