Chirp/squeek in passenger side of dash
2009 F250 CC 6.4
Today while driving I started noticing a chirping noise coming from the dash on the passenger side. It sounds like a fan going bad, but even if I shut the heat off the noise is still there. Engine RPM doesn't make a difference, it's a continuous chirp, chirp, chirp. Any ideas??
Could be? I had thought that too, but have no idea if the fan continues to run or not. Tomorrow I'll see if I can find and pull the fuse for the fan and see if the chirp stops. Thanks for the insight.
No better beer then a free beer, as long as it's cold. Chirps while parked in the driveway. Doesn't matter if the truck is moving or not so I don't think it's the console.
My 2009 had a ticking sound behind the dash on the passenger side but I really would not call it a squeak. It wound up being the passenger side dual climate control blend door actuator. I had it fixed at the delersip for around $250.00. The part was only $30.00 but I did not feel like taking a day off of work to tear into the dash. It would have been worse if it had been on the drivers side because the whole dash would have had to come out. The irritatating thing about this is now I think the driver's side one is starting to go out which does not surprise me because Ford has A TSB out on this. I just wish some customer financial assistance was included with a TSB. By the way my truck is a 2009 model with about 45,000 miles on it.
I have a similar issue with my '09 250 6.4 and was actually able to recreate it for a Ford mechanic after driving the truck for 15 minutes. After the truck warms up, a noise comes from what appears to be the climate control system in the dash. The mechanic thought it to be a climate control servo going bad or having a faulty connection, triggering it to adjust a flap or the like constantly. The truck is going in next week to repair the issue. I'll let you all know the outcome.
stefanwest
1983 - 2012 Ranger & B-Series
10-25-2014 07:38 PM
Junebug_
1997-2006 Expedition & Navigator
01-14-2010 06:14 AM
