You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey all im putting a 5 speed fm145 tranny under my 84 B2 off my parts 85 B2 anyhow pulled the tranny and noticed on the bellhousing there openings dumb question maybe but when i get into mud/water out fourwheeling wont my clutch and flywheel get all plugged up with crap could i even plug the bottom opening to keep most mud and water crap outta there or should i not be so worried ?? thanks
__________________ 1995 Bronco 302,3''lift,35'' Procomps,Dual exh 1981 Ford F150 302 1980 F150 Ranger XLT 300 I6 1985 Bronco II 1984 Bronco II
Dont quote me on it, but i think what you are talkin about is just the "clutch inspection hole" thingy, so i think it will be fine to block it, but maybe someone else will be 100% sure
There is supposed to be a rubber plug that fits that opening........search the J-yard.
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......450,000 miles, now on a brand new 2.8
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
My first tranny swap not to familuar so sorry for the poor info but there one opening toward the bottom and one toward the top seem to be vent hole there proubly 4'' long by 2'' wide agian migth not be a big deal just thought might save my clutch and flywheel some ?? thanks alot
i wonder the same thing sometimes, i mean they are angled to keep water out under normal conditions, but i dont know if they can be blocked off, or if they even need to be
Hole may also be for a external slave cylinder for a different application.
Got pics?
__________________
Dave
__________________
Dave
Water getting that high, the clutch may be the least of your worries. The hole is to vent heat from the clutch/flywheel area.
__________________
Dave
And I guess it is angled the opposite way to that would also make it harder to get in there Just thought i'd ask if anybody has had any proublems thanks alot old93junk
