1991 curb weight - Ford Truck Enthusiasts Forums
1991 curb weight
Old 03-06-2003, 07:20 PM
esimerly esimerly is offline
esimerly is starting off with a positive reputation.
Question 1991 curb weight
just got a 1991 f250 2wd extended cab longbed.460 engine...4:10 rear end.i am trying 2 find out the curb weight...any1 with an idea?...thanx
Old 03-06-2003, 07:38 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
1991 curb weight
A wild guess...
Your truck should weight less than 8,000. My 94 F250 4WD 460 E4OD super cab with long bed and a glass shell weighs a touch under 8,000 with both tanks full and about 600lb of passengers and junk in it.
Since yours is 2WD that should drop a good chunk. Wild guess is maybe 500 lb? The shell I think weighs about 500(eets a big one).
The weight I have is from a city dump scale.
Maybe the curb weight is listed on the door sticker?
Good Luck,
Jim Henderson
Old 03-06-2003, 09:03 PM
Flash Flash is offline
Flash is gaining momentum as a positive member of FTE.
1991 curb weight
Out of the 91 Ford guide, its curb weight is 4705 lbs. I suspect that is probably shipping weight which does not include weight of fluids such as gas, oil, etc.
Old 03-06-2003, 09:19 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
1991 curb weight
Curb weight DOES include all fluids. 4700 sounds about right. With all the cargo I normally carry and the bumpers I've added, my truck rolls around right at 6000lb.
Old 03-07-2003, 02:42 PM
PHS79 PHS79 is offline
PHS79 is starting off with a positive reputation.
1991 curb weight
I would assume that your truck is more than 4,700 lbs. More like 5,200-5,500lbs. My 94 F-150 4X4 reg cab, long box, 300-6 with 5 spd weighs in at 4630 lbs. Thats with just my tool box and about 100 lbs of log chains in it, so about 4,480lbs curb weight. My old boss had a 85 F-150 4X4 reg cab long box, with 351 HO, and C-6 auto weighed just over 4,700 lbs. Thats just the truck nothin else in it. A buddy of mine has a Chevy 2500 2wd, ext cab, long box, with 350/auto. Last time we hauled wood, his truck weighed exactly 1,000 lbs more that my truck after we unloaded, 5,520 lbs.
Old 03-07-2003, 09:46 PM
1991 curb weight
thanx 2 every1 that replied.i am taking it to the landfill 2morrow were they have scales....i will let every1 know......thanx again
1985 f350 4 door dually curb weight? MUSKRATT2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 11-03-2012 10:17 PM
76 F-150 curb weight Y82WS6 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-27-2012 11:24 PM
curb weight law34 1967 - 1972 F-100 & Larger F-Series Trucks 27 01-05-2011 04:37 PM
Curb weight 99' F-350 club cab dually ? 2cylguy 1999 - 2003 7.3L Power Stroke Diesel 8 07-04-2006 12:03 PM
Curb weight of 65 F-100 hpguy 1961 - 1966 F-100 & Larger F-Series Trucks 6 12-29-2000 05:10 PM
Tags
1991, 1994, 4630, 91, cab, curb, empty, extended, f150, f250, ford, gross, ranger, v6, weight, wid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
