Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape & Escape Hybrid
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
  #1 (permalink)
Old 01-09-2011, 03:30 PM
dankisor dankisor is offline
Garage is empty, add now
dankisor is starting off with a positive reputation.
2003 Escape XLT error codes
I have a 2003 Escape XLT with a V6, 164,000 miles. I am getting error codes P0302 and P0316. I have read the forum and searched Google, and it appears and the most likely cause is the coil on the #2 cyclinder. Is that a good assumption? Assuming it is, I guess you have to take off the intake manifold to get to that coil/plug. I have a few questions and would really appreciate some advice.
<O</O
- Is that a job I can take on myself or are there some tricks to getting the manifold back on correctly.
- Also would you agree that I should go ahead and replace all three coils under the intake manifold since I have to take it off anyway, or would you just replace the #2?
- Lastly, I have found some coils for $45-50 online and they are about $70-80 at the local parts stores. Is one brand better than the other or should I buy the lower priced coils?
I really appreciate any advice you guys can provide. I am mechanically inclined and have did a lot of work on cars in the past, but have never pulled a manifold.
Thanks! Dan
  #2 (permalink)
Old 01-09-2011, 07:23 PM
tonyford tonyford is offline
tonyford is starting off with a positive reputation.
I had 2 coil packs go within 2 months of each other. At about 115,0000. They go without warning. You know they are gone when it rains. They can go at anytime, but they also can last the lifetime of the vehicle. Best to replace the coils as they go bad.
Mechanic charged me $200 to replace each one. Not sure if they were in front or the manifold had to come off.
If you can do this yourself, you will save a bit of cash.
__________________
When buying only 2 tires, make sure they are mounted on the rear of the vehicle. Could save your life!
  #3 (permalink)
Old 01-09-2011, 10:51 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
http://www.ford-trucks.com/forums/45...ark-plugs.html
this is a great how to and should be made a sticky....
I would also change the lower gaskets and in stall a new pvc valve.
__________________
Buy American your job depends on it.
  #4 (permalink)
Old 01-10-2011, 08:17 PM
Thanks much for the advice. I will definately replace the PVC and gaskets as well.
Tags
0316, 2002, 2003, code, codes, engine, error, escape, fault, ford, forum, hybrid, p0302, p0316, reset, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
