Deser racing ranger?
I have decided to build the 91 ranger that i have sitting out in the ding weed into a desert race truck. one, because it is just sitting back there rotting and two, because there is a desert short course offroad racetrack being put in her in madras. does anybody have any suggestions. the truck doesn't have an engine transmission or transfer case right now so i will probably start looking for something. also, i think that i'll cut and turn the front twin traction beam suspension and put some larger spring up front and add some leafs in the back. I have a set of 32" BFG all terrains that i'm planning on throwing on there.
Must have been the FM146 or Mitsubishi trans, my TK-5 has 390,000 miles on it and still going strong.....A little noisy on cold mornings, but gone within a couple miles.
There were about 6 different manual gearboxes put behind 2.0s,2.3s, 2.8s, 2.9s, 3.0s and 4.0s through the years, maybe more, its hard to say with certainty.
I know the TK-4/5 trans is supported by Advanced Adapters to be run behind 302s and 351w Ranger V8 swaps, so it is tuff!
There are SO many crashed Explorers in the J-yards that they are a great source of parts, cheap too!
I am concerned about adding the extra weight but the short course racing that i hope to be doing is going to require accelerating out of corners into jumps, and breaking all four loose to drift corners, so i do think the power could help. I'm sure i wont be at that level right out of the chute, but thats what i'll be working toward.
I can't find them right now, but there are a couple of companies that used to support performance goodies for the OHV Ford 4.0
There is also the SOHC 4.0 used in new Explorers and Rangers that is well over 200hp, but it comes with more electronics, more sensors, different trans, and reliability problems with cam phasers in earlier versions........Depends how ambitious you are, I really should not quote on this motor as I have little experience with it.......The old push-rod 4.0 is a good simple, stout engine.
I have heard it had teething troubles for the first 2-3 yrs...........My dad has a 4.0 SOHC in his 09 Explorer, no problems and tows a boat like a V8.
4.0 OHV in a Aero has a lot of work to do!
My wifes 96 Explorer Limited 4.0 OHV will run 80 on the freeway all day long, and feels only slightly less powerful when pulling the boat, than Dads 09.
