testing ignition coils - Ford Truck Enthusiasts Forums
Old 11-24-2014, 07:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Old 01-09-2011, 12:12 PM
DOC1KOC1 DOC1KOC1 is offline
DOC1KOC1 is starting off with a positive reputation.
I have an '05 f150 w/5.4l that engine is skipping...I want to check the ignition coils. Can I simply ohm them out? I have done that on a '98 5.4l. But the Haynes has nothing stating what the reading should be...Any imput?? I have done searches in the forum but cannot find what I'm looking for.....Thank You...........DOC
Old 01-09-2011, 01:16 PM
ChrisCarter ChrisCarter is offline
ChrisCarter is starting off with a positive reputation.
Test a few of them and if what you get is the same readings on all but one or two then you'd have some bad coils...
Heres an article on the (COP's) hope this helps Part 1 - Testing the FORD Coil-on-Plug (COP) Coils
Old 01-09-2011, 05:04 PM
problem fixed
Just a follow-up... I tested a new one and it was .6 ohms. So I tested the reast and they all tested fine. I did find 1 with the clip broken and wasn't very tight. I cable tied it and all is well.... I just wonder why they don't list what the reading should be in the repair manuals.....
DOC
Old 01-10-2011, 11:03 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
With many miles on the truck I would suggest changing to a set #140033-8 of Accel COPs. Summit has them for around $270 + handling fee for the set. I put the 7989 Champion plugs and the Accel COPs in mine @ 71,000 with no problems since. I have over 31k on them. I noticed you had an '05 which has had problems with the injectors sticking. You should check that out also. They usually flood a cylinder and can ruin the cats in some cases. If you change your plugs have a Lisle tool set on hand and follow the TSB. Let the plugs soak overnight if possible. I broke 7 when I changed mine. Patience is a must on this engines.
Old 01-10-2011, 11:14 AM
8UP 8UP is offline
8UP is starting off with a positive reputation.
I would replace your plugs first.
Old 03-20-2013, 07:10 PM
shawngilmore1967 shawngilmore1967 is offline
shawngilmore1967 is starting off with a positive reputation.
Here's the deal with plugs and coils on these trucks. I ran Seafoam through my fuel and had a fuel injection cleaning done to my truck prior to replacing the plugs. When replacing the plugs, do no use a ratchet to loosen (until they are loose), use a small breaker bar (gives you more control of torque). Gently try to tighten and then gently try to loosen, then continue to work the plug, do not force. To make things easier remove the PCV line on the right side of the engine and unbolt your ECM to gain better access to the back two plugs on the left. Testing the coils are simple, place both leads on the two prongs, they should ohm between 5,000 to 6,000ohms, higher than 6,000 or lower than 5,000 is a bad coil. By the way, I broke zero plugs.
Old 03-22-2013, 07:16 PM
Infantryman1991 Infantryman1991 is offline
Infantryman1991 is starting off with a positive reputation.
i keep getting a cylider 2 misfire. i replaced the coil and that didnt work. should i assume its the plug. if so would it hurt anything if i just replace one? im low on cash at the moment dont have enough for all 8 right now.
Old 07-30-2013, 04:49 PM
slimbo13's Avatar
slimbo13 slimbo13 is offline
slimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputationslimbo13 has a superb reputation
inspection
i had a misfire my coil ended up being cracked it was orginal ford part
2002 Expedition 5.4L coolant leak avwormfarm 1997-2006 Expedition & Navigator 1 01-29-2016 11:48 PM
Vacuum line confusion on 2bbl Carb WhoaFiveOh 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-18-2013 05:41 PM
Oil change intervals---- longview1 6.4L Power Stroke Diesel 7 05-22-2011 09:58 PM
'05 Expedition shut down while driving DOC1KOC1 1997-2006 Expedition & Navigator 1 10-19-2010 05:21 PM
'05 Expedition keeps blowing fuse #12 (fuel relay) DOC1KOC1 1997-2006 Expedition & Navigator 1 01-04-2010 01:16 PM
Tags
1400338, 2004, 2005, 2008, 54, accel, check, checking, coil, coils, f150, ford, ignition, spark, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
