bolt on four link - Ford Truck Enthusiasts Forums
bolt on four link
Old 01-09-2011, 11:12 AM
bighalt56 bighalt56 is offline
bighalt56 is starting off with a positive reputation.
bolt on four link
Want a bolt on four link and airbags for my 56 f100. The ones i see go in same spot as the leaves. Im not able to get to my truck so could someone tell me how far the leaves are in from the edge of the bed. Im planning to tub it and would like some big meats under it.
Old 01-09-2011, 01:23 PM
lgfuller lgfuller is offline
lgfuller is starting off with a positive reputation.
not sure on the distance for the leaves. and i not sure on the prices, but check out Hotrods to Hell they have a bolt on setup and build kits for the 53-56 fords. its a long "truckarm" rear suspension. they call it "centerdrive" but its basically what you would find under a NASCAR. just something that i cam across looking to do the same style setup on my 52.
Old 01-09-2011, 01:49 PM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
BACAGrizz has a good reputation on FTE.BACAGrizz has a good reputation on FTE.
The frame is 34 inches, the bed is 49", the leaves are outboard of the frame. You won't be able to tub it much unless you put the 4 bar under the frame and if I am not mistaken the bolt in goes on the outside of the frame.
I used a triangulated weld in unit which places the lower bars under the frame and it gives me all the room from the difference in the widths to put tubs. The tires I want to use on the rear are 295s and the rims have enough back space and offset to keep the tires inside the fenders allowing me to tub the bed and still have a few inches between the tire and the frame.
about to purchase a new rear end Four.on.the.floor 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 05-15-2015 01:27 PM
four link suspension? imlowr2 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 11-19-2014 09:52 AM
53-56 wheels Silent Thunder WTB - Parts & other 1 04-06-2014 08:06 PM
58 f100 restore mark_roberts33 1957 - 1960 F100 & Larger F-Series Trucks 2 01-29-2014 09:02 PM
Welader Series Triangulated 4 link v2addict 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 03-12-2013 09:28 PM
Tags
1956, 49, 56, airbags, bolt, bolton, classic, f100, f350, ford, frame, link, ranger, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
