292 oil filter adapter
Stupid questions. Did my 64 f 250 with the 292 come with a cartridge style oil filter? If it did a PO installed a adapter kit. Where do I find the adapter o-ring? I can find the adapter kits with o-ring but not the o-ring by itself. If someone has a part # I would really appreciate it. MY local parts stores are no help I am having better luck ordering online. Thanks
on
Well I am thinking that in 64 it would have had a spin on filter. Nappa part # 1515. Not sure on the trucks though. Anyway the spin on is not as good a filter but is easier to change and does not need changed as often. What I mean by that is the canister or sock type filters smaller partials better but can plug up sooner. There ya go, my .02
Thanks Arctic y block I appreciate your .02 . My problem is that there's is a plate behind the oil filter that the oil filter screws to there is a o- ring that is leaking. If I would not of touched it, it would not be leaking but I had a wrench in my hand and saw a nut. This o-ring did not come with the overhaul kit. I would just hate to order a whole adapter kit for $25 and it not be right. Like I said my part stores around here are weak at best. The 3 don't even carry the canister filters. I was hoping it was the same o-ring. I agree my old 63 chevy had the canister filter, but I am a good tinkerer I change my oil a lot. Thanks again for your 2 cents.
I believe it is a gasket and not oring that goes behind the adapter plate. The gasket is included in engine gasket kits, so someone may have a spare.
Some people resort to buying a cannister filter at NAPA, just for the gasket which is included, and which I hear will fit the adapter plate. I kind of tried this once, but bought a NOS cannister and gasket on ebay. It was too brittle and out of shape to use.
on
That was my quest later today. Was to pull it apart and make sure it is a o-ring 46 y block stated it might be a gasket. Was thinking about the old chevies. I got the pan off last night with the valve covers and front cover, found a push rod had fallen out and the pan full of mud/ gunk sludge and the pick up falling apart ,kinda stopped playing with it then. Cleaning up the mess I made yesterday. Still looking for that parts person around here that is like ND. Having better luck ordering on line just makes progress slow.
redmondjp
12-27-2022 09:43 AM
Jharger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
07-21-2019 01:40 PM
Northern Econoline
08-01-2013 10:40 PM
