Tips and Tricks
Old 05-30-2011, 09:53 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is online now
okay I got one: if you have some chevy scraps layin around, the main bolts from small block chevy make good engine stand bolts for the 300
also when I had my motor out to do the rear main seal and oil pan gasket I bought two crankshaft sleeves for the rear. one cost forty bucks and came with an installation tool. the other was about ten bucks, did not come with a tool and worked real good. I tapped it on no sweat and took the forty dollar one back.
up front the harmonic balancer sleeve was a no brainer. that sucker was grooved.
Old 11-05-2011, 02:20 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
Inexpensive roller rockers
I found a way to save a buck. I love to save $. If you would like to save a couple of hundred bucks when buying roller rockers for your 300, then listen up. There is a co. on ebay, PRW, selling new 1.6 roller rockers for a bbc, with 3/8" and 7/16 stud size, for just over $200. The bbc rockers bolt right to the 300, and with the 1.6 ratio it does not move your p.rod closer to the valve, so no mods are needed.
More oil to t.gears. I read on a ford site they recommended installing a roll pin, 1/8" x 1/2" into the hole that feeds oil from the lifter galley into the t.gears. This mod brings the oil to drop right onto the gears and quiets them.
The following users liked this post:
Old 11-07-2011, 09:06 AM
Harte3's Avatar
Harte3
Harte3 is offline
Old 11-21-2011, 09:53 PM
patagoniaYblock's Avatar
patagoniaYblock
patagoniaYblock is offline
Hi , sory , I'm a little lost , is anybody in USA like the thiny six ?, here is 188"/221" , in USA I think is 200"/250" ,
If possible power up this , are pieces for this there ?
thanks
Old 01-04-2012, 06:27 AM
62RatRod's Avatar
62RatRod
62RatRod is offline
thanks
Go to that fordsix link on the message above yours they have tons of stuff about all the ford iinline 6 engines even non American models
Old 01-04-2012, 06:34 AM
62RatRod's Avatar
62RatRod
62RatRod is offline
How bout gasket matching your head. Worked wonders on my 300, did it for free, and it didn't take much time.. There's at least 1/16 to 1/8 of an inch of material all the way around the gaskets that can be taken off and smoothed. Throw some headers on it n listen to it breathe lol
Old 01-04-2012, 10:27 PM
patagoniaYblock
Ok , very thanks , I search and read this
greetings
Old 03-13-2012, 02:04 AM
thatguy931's Avatar
thatguy931
thatguy931 is offline
new to the inline 6 but not motors a detail over looked i have noticed is when doing you rocker arm setting it will change between the cold and hot settings, ie engine cold and hot. i like to do a cold setting to get it close and then go back and do a short readjust once hot. or a quick check if rollers with a gauge.
Old 03-26-2012, 04:23 PM
F-250 restorer
Offenhauser heating plate
Moderator: Is it possible to be able to have separate threads for diff. topics in the Tips section. It would make it much easier to find items of interest. Lumping it all together seems pretty sloppy.
Forum members: If you're installing an Offy DP or 'C' type manifold, you need one of these heating plates that bolt to the bottom of the manifold and allow you run engine coolant through it to keep the air/fuel mix nice and hot, so your performance doesn't fall on its face. The old Clifford manifolds don't allow for this. The newer Cliffy manifolds have their own system for coolant exchange. Another system is to install a heating plate between manifold and carb, from a 60's era galaxie, but this system, in the photo below, works much better.
Old 03-28-2012, 03:22 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
A picture of the heat plate installed:
Old 06-01-2012, 02:22 AM
68cabby's Avatar
68cabby
68cabby is offline
Where would you find this heating plate and what is the path the hoses and coolant would take? I.e. hose diagram?
Old 06-01-2012, 02:42 AM
68cabby's Avatar
68cabby
68cabby is offline
Also..is it just th c series that needs coolant ram through or do I need if for the do also?
  #28
Old 06-01-2012, 08:51 AM
AbandonedBronco
You'll need it for any intake that doesn't have the exhaust heat directly underneath.
The hose connection is almost too simple to need a diagram. Cut one of the hoses to the heater core in half and put the hose ends onto the pipes on the heat plate.
As for procuring the heat plate, it's something you'll most likely have to make yourself or have a shop fab one up. The gasket that comes with the Felpro intake/exhaust manifold gasket is a perfect template.
  #29
Old 06-01-2012, 12:43 PM
68cabby's Avatar
68cabby
68cabby is offline
Is it NECESSARY though? I don't plan on camming the 6 yet..just put in a better intake with a big 2bbl and a header as of now.
  #30
Old 06-01-2012, 12:52 PM
AbandonedBronco
Necessary, no. Desirable, yes.
It has to do with the basics of how air/fuel mixtures work. The cold intake floor will mess with any air/fuel mixture, no matter the performance parts. It can cause soggy performance/bogs under certain conditions. Heating the intake floor cures this.
The stock design accomplished this by using exhaust heat.
Quick Reply: Tips and Tricks
