DOES ANYONE HAVE THE SRL++ TUNE FROM MATT AT GEARHEAD?
01-08-2011, 04:59 PM
on
IF YOU HAVE THIS TUNE WHAT ARE YOUR EGT'S?? AND WHAT ARE YOUR HIGHEST READING ??
01-08-2011, 05:15 PM
I can punch 1300 egts with just the SRL so I watch my gauge and it has an alarm
I have all stock exhausst untill next month
what are you seeing? or is it just a question ?
01-08-2011, 05:21 PM
on
i do not have the tune yet. i hear 1250 for more then 5min you will hurt your motor.?
01-08-2011, 05:59 PM
I wouldn't do it that long ,, I hit it for about 30 seconds max
but there are so many variables like where u put the probe
etc
I would Get a EGT gauge .. get Matt's tune and if u notice High EGT's have Him dial it down
also remember u get different tunes for towing
I saw your other thread you have an EGR delete correct ?
01-08-2011, 06:58 PM
on
yes i have egr delete,cfm+,head studs,4"turbo back cat delete,amsoil oil bypass
01-08-2011, 07:00 PM
you may get away with higher EGT's if your EGR delete isn't letting exhaust into the top end
01-08-2011, 07:47 PM
Highest EGT I have had was under 1100. The boost tops out at 28. My Edge Insight records max values. With your larger exhaust, I don't think you will have any problems, so long as you don't tow.
01-08-2011, 08:02 PM
Quote:
Originally Posted by
kingtell
I've towed through the desert at 1250 for hours.
Typically you'll see higher EGT's at the beginning of a WOT run, and then the temps will fall and stabilize. Short blasts with EGT's above 1500 are not uncommon.
01-08-2011, 08:07 PM
on
thanks for the info i am going to order the 2 tunes from matt
01-08-2011, 08:33 PM
seijirou
01-01-2017 10:17 PM
smokersteve
02-14-2016 03:36 PM
BigRedTed
02-07-2016 07:31 AM
6x4Cowboy
Computer Chips & Tuners
09-04-2011 08:04 PM
dean307
11-24-2006 11:36 PM
150 ,
60 ,
60l ,
ford ,
gearhead ,
matt ,
mattat ,
matts ,
problems ,
sct ,
srl ,
tune ,
tunes ,
tuning ,
x3
