No start... again.
#48
#49
In fact, I have strong spark, good fuel pressure, and timing is good.
Compression should be fine. I have not had a chance to check it with a gauge, but it is a low mileage engine, and I put a little oil in the cylinders to raise compression.
Still nothing. It's driving me insane. I hate working on this damn truck.
#51
#52
#53
When you unplug the computer the injectors will not fire so it will not start.
The unplugging of the Computer is a test to see if spark returns only. Not to start the engine.
Sounds like it is out of time or the engine is turning too slow to start.
You need to turn the distributor while the engine is cranking and once it starts you need to time it with a timing light with the SPOUT removed. Then put the SPOUT back in after you tighten the distributor hold down bolt.
The TFI is a type of ICM.
The pick-up they were talking about is the PIP sensor switch mounted on the stator assembly inside the distributor.
#54
Subford, when I unplugged the computer, thinking it was bad, the truck still tried to fire randomly like it did. Could it be that it was firing on any fuel that could have been in the cylinders already?
The engine turns over good and strong, not slow. I have tried turning the distributor while cranking the engine to try to find the right timing to start it, and nothing works. I have disconnected the spout wire off the distributor mounted module and set the crank at TDC. Aligned the rotor and tightened down the clamp to get it in the ballpark. Checked with the light it's been perfectly on 10 degrees BTDC and just TDC. Neither worked.
Idea's?
#56
No Start...again
You have tried many things to no avail. I had a problem such as yours and after days of trying to find what the problem was, I check 3 fusible links on my F250 5.8L. Come to find out, three of the links were completely destroyed due to an internal short in the battery. After repairing the links and several other sensors that were taken out by this short, the truck started right up. Hope this helps some.
#57
An internal short in the battery will cause the voltage to drop and a drop in voltage with the resistance the same will cause the current rate to drop.
High current is what opens a fuse link or a fuse.
It is what is called Ohms Law.
#58
Okay guys, I checked out what you guys said.
I jumped the OTHER wire, the one that was not green. (It's white by the way.)
It still does not start.
Does anyone else think my computer theory may be an option? It does the same thing with the ECU plugged in or not plugged in. Fires some, and doesn't start.
I'm getting really annoyed at this damn truck.
#59
Ok, so as I'm hearing. engine spins over and tries to run kinda like an old 'hit and miss engine' but the spark is great, fuel pressure is good, timing is close enough for it to at least run like crap.
Unplugging computer is a way to confirm good strong spark but you already had good spark.
I got nutts once and hooked my timing light to the coil wire as the pos was trying to start and it didn't always flash. so I had intermittent great spark
Plugs are wet so you have fuel, start fluid doesn't help. Distributor shaft isn't sloppy sideways.
What would I do?
Let me think about this.
Just think about how glad you'll be when it's over like a bad dream
What would I do?
#60
I was speaking frin experience regardless of what Ohms Law stands for in people's mind. You will never know until you check out the Fusible Links to the important parts of your truck, i.e., ECM, starter, alternator. The fusible link from the starter relay to the starter solenoid may be at fault. However, you have several others that need to be checked out carefully from start to finish before assuming that they (the fusible links) are not at fault. Whatever the case, your problem appears to be electrically connected.
