Weight loss program for a Class B motorhome on an '89 E250 SD chassis
Received 5,160 Likes
on
Oh yes, I know. I hang around there and a couple other sites for RV-related stuff. But for the chassis stuff I look here and another site dedicated to Econolines. I don't know if I should name it or not, but you guys probably know it already. They are into the older generations of E's though, 60'-70s models.
Still have no idea about trans code G. It will have to wait until morning to crawl underneath her her and look at the ID plate.
on
Like I said only code translation I could find for G is on a Bronco page, and I'm assuming that Ford codes are all the same, regardless of the vehicle model.
Is the C6 what they normally mated to the 351 Windsor? Transmissions are something I leave to the experts, so I wouldn't know the difference between a C4 and a C6 if it whacked me in the head.
on
Well that certainly makes sense. Now I wonder why the build code on my B pillar says G. Is it a typo or would Intervec (the RV Manufacturer) swap out trannies? Can't see Intervec doing that.
So trans code G, in an Econoline means C6, and in a Bronco it means C4? That doesn't make sense either.
#30
I've wondered about what would happen if I put one of those hood wing things on her, if it would divert the air up over the top more efficiently. Kind of like the air dam you would wrap around under the front bumper, only right on her nose. I always figured they were a gimmick, but who knows? She tends to pitch and yaw in x-winds, so even if it would help curb that, it would be a bonus.
