1992 302 knock sensor - Ford Truck Enthusiasts Forums
Old 01-08-2011, 01:57 AM
carter2011 carter2011 is offline
carter2011 is starting off with a positive reputation.
Hey. I am new to the forum and my truck is a 1992 F150 5.0/302 4X4 swb. I recently bought the truck and in process of complete restore have found out that the manufacture has discontinued the knock sensor and I have had no luck at local parts shops. Truck runs great but stil would like to find a replacement for it. If anyone has an idea please HELP!
Old 01-08-2011, 08:44 AM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
I have the same problem...Mine is DESTROYED!!!!!..Once again...DESTROYED!!!! It amazes me how the P.O.'s drive these vehicles in the GROUND!! Just continue to dump oil in it and some gas, maybe put some air in the tires(Only 'cuz they LOOK low) drive it further in to the GROUND...AND AT THE SAME TIME, GET IT INSPECTED!!!!!!!!
I did see some available thru E-Bay. You can do a search here, hence someone was just asking for one for a '92 4.9L and could not find one anywhere.
Old 01-08-2011, 10:51 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
This thread from another forum has some great info: FullSize Bronco.com - Knock Sensor
Old 01-09-2011, 08:32 AM
Thanks rla2005! I've been looking for that.
Old 01-09-2011, 11:54 AM
Kapusta's Avatar
Kapusta Kapusta is offline
Kapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to all
Looks like I'll be saving the KS from my old 5.0L. That's an expensive little part.
Old 01-09-2011, 02:08 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Quote:
...I wound also keep the roller cam & lifters , dog bones , and the spiders from the 94 , and the distibuter , guys on here will buy them from you , its a good upgrade from the older 302s....Lew
Old 01-09-2011, 02:34 PM
Kapusta's Avatar
I plan on keeping the distributor from the old 302 as well since it's almost new. I am planning on selling just about everything else from the old 302 to try to recoup some of my losses.
Old 01-15-2011, 05:44 PM
kingfoot kingfoot is offline
kingfoot is starting off with a positive reputation.
can anyone tel me wer its located the nok sensor that is
Old 01-15-2011, 06:45 PM
Should be located on the back of the block, below intake manifold, close to the bellhousing.
Old 01-15-2011, 06:46 PM
Kapusta's Avatar
At the back of the block on top behind the intake manifold. At least I think that was it.
Old 01-17-2011, 05:03 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is online now
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Here's a picture of where it is:
Old 01-25-2011, 01:38 PM
mine is spark knocking very bad unles i use 93 octane if i un plug it will it help
Old 01-25-2011, 01:52 PM
Kapusta's Avatar
^ unplugging a KS will not help. It might even cause a fault code and the CEL light to turn on. You need a new one.
Old 01-25-2011, 02:38 PM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
If sensor detects knock...retards timing 4 degrees. If you are not expierencing knock you could run it without....may or may not set check engine light. I believe the trucks were the only 5.0's to even get the sensor. I am guessing due to possible pulling of heavy loads with today's great fuels.
Old 01-25-2011, 02:53 PM
yea wer u find that
rocker arm kevinclark1990 1987 - 1996 F150 & Larger F-Series Trucks 3 06-02-2015 06:14 PM
knock sensor ole88 1987 - 1996 F150 & Larger F-Series Trucks 2 12-04-2011 06:57 AM
Knock Sensor Brian_W 1987 - 1996 F150 & Larger F-Series Trucks 3 04-23-2011 06:27 AM
Coolant temp sender and sensor location? BigBlue92 1987 - 1996 F150 & Larger F-Series Trucks 2 03-27-2011 09:10 AM
302 knock sensor 1ford Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 01-07-2004 06:43 AM
Tags
150, 1992, 302, 50, 88, 92, f150, ford, knock, location, pickup, sbf, senser, sensor, sinsors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
