Steering Column Question
Old 01-07-2011, 08:21 PM
ZOOT's Avatar
ZOOT
ZOOT is offline
This is a darksider question. I have a Mustang II set up on my truck and would like to use the original column and steering wheel and use the original horn button. So far I've figured the original steering shaft would work if I put in a bearing at the bottom of the column for strength and the splined end could be mated to a universal joint. The original horn wire goes down the center of the steering shaft which would be twisted apart in the universal joint. The question is if there is a way to original horn button work??
Old 01-07-2011, 08:26 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
There is a kit I've seen from some vendor that lets you do exactly what you're talking about, and lets the horn wire come out the side of the column, near the bottom. I've seen guys talk about it here before. I'm sure someone knows what and where it can be found.
Don't forget you also need to build a support clamp and mount for the bottom of the column, where it goes through the floorboard/firewall.
Old 01-07-2011, 08:34 PM
ZOOT's Avatar
ZOOT
ZOOT is offline
Yeah, I hear you. I have a column from a 1977 F100 in there now which works fine. I what the interior to look more original. Wonder where I might find the kit you mentioned. Is there a thread on this site which discussed this? HOW COME I HAVE AND AD FOR A CHEVY TRUCK ON MY POST ? I'M A MEMBER. I THOUGHT NO ADS ON MEMBERS POSTS. WHAT'S UP THIS THAT ? A CHEVY !!!!
Old 01-07-2011, 10:38 PM
gobybike's Avatar
gobybike
gobybike is offline
Try this guy. I ordered the kit you are talking about but have not gotten it yet so I can't speak to how well it works. He is a good guy and will talk to you about it and send diagrams if you email him. Good luck.
Chad Blundell
Blundell Speed & Machine
735 N. Cypress St.
Orange CA 92867
714-744-1900 factory
714-393-8713 cell
blundellspeed@att.net
Old 01-08-2011, 12:38 AM
t900enforcer's Avatar
t900enforcer
t900enforcer is offline
Any idea what the cost of something like that is?
Thanks
T900
Old 01-08-2011, 08:07 AM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
guess you could install some kind of insulated band around the shaft with brushes like a starter to come out in the cab for your horn...
Old 01-10-2011, 11:09 AM
ZOOT's Avatar
ZOOT
ZOOT is offline
Hey, thanks for the input. Gobybike, thanks for that contact, I'll check it out. Let me know when you get the kit. P M me or post it. I'm wondering about the quality of the parts, if they fit etc. Thanks again
Old 01-10-2011, 11:18 AM
tip49's Avatar
tip49
tip49 is offline
Blundell Speed
I bought the kit after seeing it in Classic Truck mag; haven't installed as of yet but know you need to have stock column ID to make it fit.
Tom
Old 01-10-2011, 11:34 AM
ZOOT's Avatar
ZOOT
ZOOT is offline
Column ID? Do you mean a number or the inside diameter? I get classic trucks, don't seem to remmeber seeing the kit. What's the company name?
Old 01-10-2011, 08:56 PM
VespaJay's Avatar
VespaJay
VespaJay is offline
Here's the website for Blundell Speed & Machine:
Blundell Speed and Machine
It has pics & price of the horn saver kit.
rzns60
09-12-2020 12:02 PM
mikeceli
07-19-2016 03:51 AM
fabieber
01-31-2016 01:17 AM
427 fordman
12-07-2015 11:35 AM
scottlathrop
18
12-31-2013 01:36 PM
Quick Reply: Steering Column Question
