How much does a gallon gasoline weigh? - Ford Truck Enthusiasts Forums
Old 10-18-2002, 07:16 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Man, I know this but I cannot remember! ARGH!
Help?
Old 10-18-2002, 07:18 PM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
6.1 lbs.
Old 10-18-2002, 08:21 PM
superdutyspv superdutyspv is offline
superdutyspv is starting off with a positive reputation.
5 lbs.
Old 10-18-2002, 08:42 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
I believe a gallon of water is close to 8.
Aviation fuel (100 LL) is at 6 lbs.
So I would not be surpised if auto fuel weighs less.
Old 10-18-2002, 09:12 PM
alanscott's Avatar
alanscott alanscott is offline
alanscott is starting off with a positive reputation.
Depends on who made it, 6.0 - 6.2 should put you in the ballpark, remember it'll be a little heavier in the winter. White gas ( well casing, Coleman Fuel, solid natural, seems to have a lot of nicknames) will come in around 5.6 or so
The same varibles apply to diesel but you can figure #2 at around 7.2 and be close.
Water is heavier than gasoline, diesel and motor oil, thats why it settles to the bottom and can rust your tanks or oil pan.
Old 10-18-2002, 09:16 PM
94van 94van is offline
94van is starting off with a positive reputation.
1 gallon of gasoline = 6.1 lbs.
1 gallon of fuel oil = 7.7 lbs.
Source: Ref 389.103 J Jones, Stacy. WEIGHTS AND MEASURES.
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Old 10-19-2002, 10:23 PM
Monsta's Avatar
Thanks all!
Old 10-20-2002, 01:53 PM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
Density of fuel, most typical value: 42.5 lb/ft^3
42.5 lb/ft^3 * 1 ft^3/7.48 gallons= 5.68 lbs/gallon
source: Fundamentals of Fluid Mechanics, 4th Edition, Drs. Munson, Young, et al. 2002.
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old 10-20-2002, 02:37 PM
76supercab 76supercab is offline
76supercab is starting off with a positive reputation.
Doesn't it depend on temperature? That's why in aviation they referr to pounds of fuel instead of gallons. If the temperature goes up the fuel will be less dense and there will be less energy in a gallon, and the plane will run out of fuel sooner and come crashing down.
I know that the values given will be close approximations.
Old 10-20-2002, 06:32 PM
TorqueKing's Avatar
It does somewhat depend on temperature, but not very much. The numbers I posted were for gasoline at 60 degrees farenheit.
"The value of density can vary widely between different fluids, but for liquids, variations in pressure and temperature generally have only a small effect on the value of rho (density)."
-Fundamentals of Fluid Mechanics, Fourth Edition
The TorqueKing
Old 10-21-2002, 04:19 PM
alanscott's Avatar
Instead of all this book lernin', why not just use the ole' handy dandy hydrometer and check the specific gravity from a sample taken directly from your tank?
*Warning*
This method may cause some people to doubt printed material.
OOps, forgot to include the specs from last night :-(
6.143 pounds per gallon @ 50.4 degrees.
Old 10-21-2002, 11:36 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
i know that farm gas weighs 8lbs avg, and tha water weighs 10avg per gallon.
Cody, Coutts Alberta
82' Flareside: zoom zoom doesn't even begin to describe it, 2/4 Drop, Soon to have 325hp 351 Clevo (maybe more,in a 3600lb truck)Backed by a C6 with a 2000 rpm stall and a 3.50 9 incher, American Racing AR-23 (series 23) wheels, Upgraded interior, Sony Xplod stereo
Old 10-22-2002, 01:45 AM
TorqueKing's Avatar
So you can use your hydrometer to find that most gasoline should be around SG~.68 which can be proven by
42.5/62.4=.681 (specific gravity is the ratio of the density of a fluid to the density of water)
water wieghs 62.4/7.48= 8.34 lbs/gallon
8.34 * .68 = 5.67 lbs/gallon
Don't beleive the numbers? Go out and test them, they're every bit as accurate as you can measure them.
The TorqueKing
Old 10-23-2002, 07:48 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
stop playing with gasoline ! sombody's gonna get hurt!
Rich
Old 10-23-2002, 11:27 AM
alanscott's Avatar
Oy! :-X23
>The TorqueKing
:-X23
2007 250 Havecooker 1999 to 2016 Super Duty 0 01-18-2017 11:32 AM
determining truck build date Jaime74656 1999 - 2003 7.3L Power Stroke Diesel 1 12-25-2015 09:53 AM
so whos ready for snow? nflfreak43 Tennessee Chapter 101 02-10-2010 01:47 PM
I did the swap argve 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-19-2001 08:43 PM
I am in need of.. martinb 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-09-2001 08:17 PM
Tags
10, 20, 22, 82, aviation, diesel, fuel, gallon, gallons, gas, gasoline, lbs, super, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
