codes 122 114
Old 01-07-2011, 11:42 AM
CouldreyFord's Avatar
CouldreyFord
CouldreyFord is offline
codes 122 114
122
114
my code reader (3145) came up with these codes, but i have no idea where to get started.
Anyone come up with these?
95 ford f250 5.8,
Old 01-07-2011, 01:22 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
Ford Fuel Injection » 3 Digit Self-test Codes 111-171
DTC 122 indicates the TPS voltage is too low with the throttle closed.
DTC 114 indicates the ACT sensor was out of range during the test. That can be caused by excessive cold or hot weather when running the tests.
Look here for expected TPS values: Ford Fuel Injection » Throttle Position Sensor (TPS)
Look here for expected ACT values: Ford Fuel Injection » Air Charge Temperature (ACT)
Old 01-07-2011, 02:27 PM
CouldreyFord
thanks ill go it that, and let the truck warm up and run the codes again
Old 06-11-2014, 07:29 PM
Aaron89ford250's Avatar
Aaron89ford250
Aaron89ford250 is offline
got code 22 and 122
any one know how to fix a truck that wont start with the code 22 and 122?
Old 08-10-2022, 07:05 PM
knobbytrav's Avatar
knobbytrav
knobbytrav is offline
6th Gear
Did you figure out our? I have the same thing.
Old 08-11-2022, 05:59 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,344 Likes on 1,061 Posts
The original post was from 2011. You are asking Aaron who only had this one post in 2014 and hasn’t been back. The third problem is that you did something wrong. You will get either two or three digit fault codes: not a combination of both. I suggest you start your own thread and rerun the KOEO self test and let us know what vehicle you are working on.
The following users liked this post:
carlos perez
08-19-2019 04:26 PM
smilespergallon
08-02-2015 10:34 AM
scouts5454
01-05-2015 08:36 AM
scouts5454
20
12-13-2014 09:42 AM
grindit60
15
12-01-2013 09:01 PM
Quick Reply: codes 122 114
