codes 122 114 - Ford Truck Enthusiasts Forums
codes 122 114
Old 01-07-2011, 12:42 PM
CouldreyFord CouldreyFord is offline
CouldreyFord is starting off with a positive reputation.
codes 122 114
122
114
my code reader (3145) came up with these codes, but i have no idea where to get started.
Anyone come up with these?
95 ford f250 5.8,
Old 01-07-2011, 02:22 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Ford Fuel Injection 3 Digit Self-test Codes 111-171
DTC 122 indicates the TPS voltage is too low with the throttle closed.
DTC 114 indicates the ACT sensor was out of range during the test. That can be caused by excessive cold or hot weather when running the tests.
Look here for expected TPS values: Ford Fuel Injection Throttle Position Sensor (TPS)
Look here for expected ACT values: Ford Fuel Injection Air Charge Temperature (ACT)
Old 01-07-2011, 03:27 PM
thanks ill go it that, and let the truck warm up and run the codes again
Old 06-11-2014, 08:29 PM
Aaron89ford250 Aaron89ford250 is offline
Aaron89ford250 is starting off with a positive reputation.
got code 22 and 122
any one know how to fix a truck that wont start with the code 22 and 122?
1994 F150 DTC help smilespergallon 1987 - 1996 F150 & Larger F-Series Trucks 3 08-02-2015 11:34 AM
P1876 code carlos perez Clutch, Transmission, Differential, Axle & Transfer Case 1 07-27-2015 07:24 AM
94 f250 fires but won't run scouts5454 1987 - 1996 F150 & Larger F-Series Trucks 4 01-05-2015 09:36 AM
94 f250 fires but won't run scouts5454 1987 - 1996 F150 & Larger F-Series Trucks 20 12-13-2014 10:42 AM
1993 F150 5.8L Computer Issues grindit60 1987 - 1996 F150 & Larger F-Series Trucks 15 12-01-2013 10:01 PM
Tags
114, 122, 1987, 1992, 58, 95, code, dtc, f150, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
