7.3 water pump problem - Ford Truck Enthusiasts Forums
Old 01-07-2011, 08:19 AM
302grabber 302grabber is offline
302grabber is starting off with a positive reputation.
I was driving my 93 f-250 recently when the water pump shaft broke, dropping the fan into the shroud. What could have caused this, is it possible the pump locked up? What is involved in changing the water pump out, as in what else will have to be removed? Thanks in advance.
Old 01-07-2011, 10:18 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Did the shaft break or the fan just unscrew from the pump.
Old 01-07-2011, 10:30 AM
Navasota Navasota is offline
Navasota is starting off with a positive reputation.
Eletrical Problems
Hello to all, I Need help with a 2000 Ford F250 Lariat cc 7.3 diesel. When it rains the horn starts blowing the heater comes on and the inside lights come on all without the key being in the switch, I took the batteries loose to stop all problems . It only do it when it rains, can anyone please tell me where to start?
Old 01-07-2011, 10:55 AM
turbill's Avatar
turbill turbill is offline
turbill is starting off with a positive reputation.
Quote:
not a moderator but I'll say it anyways sorry if its not my place.
First wrong section your looking for the powerstroke section. I think two forums up for your year,
And second dont hyjack threads start a new one in the proper section.
hope you figure out your horn
and sorry 302grabber
Old 01-07-2011, 11:02 AM
I believe the shaft has broke off.
Old 01-07-2011, 11:07 AM
I'm sorry Turbill, didn't mean to step on anyones toes. It's my first time trying to post but i will get it thanks.
Old 01-07-2011, 11:19 AM
turbill's Avatar
no problem nava just looking to help
Old 01-07-2011, 05:34 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Quote:
If the shaft broke off, you have no choice but to replace it. As to why it would break, beats the hell out of me, unless it locked up real hard all of a sudden. Check to make sure its the pump shaft that actually broke, and not the fan clutch. I'm trying to remember what it looks like... but the fan clutch attaches to the water pump, and the fan attaches to the fan clutch (I think thats how it is). Another possibility is that one of the fan blades is broke or bent, and that threw the balance off and the vibration broke the shaft.
As far as replacing it, do a search, there are plenty of threads with good directions. One thing to note, watch out for the bolt lengths, depending on the water pump, some are shorter than others for the ones that penetrate the timing cover. If those are replaced with longer ones, they can contact the timing gears. The new pump will have directions, and I know there is a picture on here if you search for it.
Old 01-07-2011, 06:24 PM
frodfreak's Avatar
frodfreak frodfreak is offline
frodfreak is starting off with a positive reputation.
is there anything wrong wit the rad. or fan? were u leaking coolant before? if so the pump houseing was most likly cracked this happened on my 5.0
Old 02-04-2011, 11:04 AM
Steering Problems
Navasota- Hello to all, I Need help with a 2000 Ford F250 Lariat cc 7.3 diesel. I had all new ball joints put on and now the truck has a lot of play in the steering, it is hard to keep it in the lane when driving are if i hit a bump. what else could this be? my wife is scared to drive with this happening. If you have any imformation it will be greatly appreciated,Thanks
Old 02-04-2011, 11:19 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Navasota,
You will get much more help in the correct forum for your truck, this forum is for the PRE POWERSTROKE diesels. i.e. pre 1994.5 ...
You want these two forums: 1999 - 2003 7.3L Power Stroke Diesel or Super Duty & Heavy Duty
-Enjoy
fh : )_~
T444E water pump A/Ox4 1999 - 2003 7.3L Power Stroke Diesel 191 07-04-2016 08:53 AM
Water pump replacement on a '92 460 - a few questions SoCalAngler Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-10-2014 05:23 PM
Electric Water Pump on a 300 JLaw92 Ford Inline Six, 200, 250, 4.9L / 300 4 02-14-2012 09:46 PM
Water pump on 7.3 powerstroke 4X4 IN REFUGIO 1999 - 2003 7.3L Power Stroke Diesel 21 08-02-2005 08:47 PM
water pump rotation dmc919 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 05-12-2004 06:48 PM
Tags
1999, 2000, 73, clutch, diesel, f250, fan, ford, locked, powerstroke, problem, pump, replacing, water, waterpump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
