how do i know if i need to replace the catalytic converter in my ford bronco 1994
I have a 94 bronco and have been told I need to replace mt catalytic converter, among several other things . I know nothing beyond how to change my tire and oil if I absolutly can not find some one to do it for me (. However , I don't want to just let any ol' " I can help ya little lady I am kinda handy and know what I am doin " kinda guy do it and its sittin in my front yard and it won't crank and its my only car and i gotta get to work so I gotta do something.
Ok , so it doesn't want to go , like my foots on the gas and nothin , can't get it over like 15 for ever, it kinda makes a poping noise , it smells like i dont know boiled eggsish kinda smell which i am told is exaust, it kinda jerks and stutters and it slows down and sometimes dies even when i am pressing the gas , it acts like its out of gas . I got it home but it wont even start. I want to take it to mechanic but I have to get it to start fisrt and every guy on my block has stopped by with a different idea of whats wrong and how they can help. .... please help !
The rotten egg smell is usually from a clogged cat. It sounds like its plugged up pretty well, especially if its causing running problems like that.
Take it to a local exhaust shop. Most of them will test your catalytic converter for free and will tell you if its plugged up. If so, have it replaced.
Another option for that sluggish of performance would be a fully clogged fuel filter. If gas can't get to the engine, it can't go. But the smell you're describing makes me think a cat.
Lastly, you can always have a place test your engine codes. That will tell you a lot. Again, a lot of places will do it for free.
A valid point, FordManMt. However, a functioning catalytic converter may not be removed from service by federal law regardless of the existence of inspections. If it fails, and the vehicle is not required to pass said inspections (if they exist where you are) then, and only then, may it be removed/bypassed. Catalytic converters that are functioning properly are completely passive devices and as such have no effect on exhaust auditory signature or the flow rate.
Mine definitely affects my exhaust sound.. and forget federal law, local law, even without inspections, are very pro-cat. I can't find an exhaust shop in a 100 mile radius that will touch anything catalytic converter forward. If they're certified and get caught (as simple as someone telling on them if THEY get caught) they can face fines up to $10,000 .. at least, that's according to the shops.
If I want a new cat, I *have to* take it to the dealer.. it's sort of rediculous
and when you get a ticket here there is a checkbox for improper exhaust/missing catalytic converter... though I doubt it is enforced, people let their exhaust go without repair even in brand new vehicles.
Hopefully you don't have to face the same kind of laws.. replacement cat can be expensive if the mechanic wants to or has to do it by the book.
The drawback to leaving a bad catalytic converter in place is that it DOES affect noise and flow rate. The substrate inside a functioning cat has hundreds of linear passages that allow exhaust gasses to flow through it. A cracked or clogged substrate reduces flow and creates turbulence inside the exhaust plumbing effective creating noise and reducing flow. There can be enough clog created to actually stall the engine, burn valves, and make really pretty red colors come out from under the vehicle at the point of the clog.
All vehicles need a catalytic converter, regardless of whether or not its required. They reduce pollution, and as someone whose eyes, nose, and throat are one fire when we have a few days of no wind and the smog sticks around, I know personally what good they do.
Yeah, a hybrid may cause more pollution to build but that's beside the point. My 30 year old truck with a cat puts out less pollution than my 30 year old truck without one. I could care less about the 2hp I lose. It's insignificant.
