94 Ranger Clutch Problem - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-06-2011, 11:06 PM
nfuller nfuller is offline
nfuller is starting off with a positive reputation.
So a few months ago my truck became extremely difficult to put into gear. At first I thought that maybe my clutch was gone, but when I released the clutch, it stalled out. I had my dad bleed it, thinking there might have been air bubbles, and it worked fine for about a week. Then it happened again, so I brought it to garage, where they bleed it and sent me on my way. A week later, I was back to square one. The garage had looked at the slave cylinder and said it was not leaking, and I had my dad replace the master cylinder, he bled it and did everything he was supposed to. It again worked fine for about a week. My dad seems to think that air got in when he did the master cylinder, and just needs to work its way out, but it's been a while, and I have gotten stranded one too many times at night in the city. Every time I lose pressure I fill the reservoir back up and he lets air out of the bleeder thing. I was wondering if it could be the slave cylinder, even though it does not appear to be leaking. And if I do the slave cylinder, should I do the whole clutch at the same time? Or are there other ways in which air can get into the system? I'm a little lost at this point.
Bled the slave cylinder, Now no clutch pressure? brc777 Ranger & B-Series 19 04-02-2015 01:39 PM
Bad Slave Cylinder??? uh60 1987 - 1996 F150 & Larger F-Series Trucks 9 11-10-2013 08:45 AM
New clutch slave cylinder seal leaking jkschneider 1987 - 1996 F150 & Larger F-Series Trucks 21 01-25-2013 01:42 AM
Perfection brand slave cylinder issue duckshepherd Ranger & B-Series 2 03-19-2011 03:01 AM
1994 B4000 4x4 :: New Clutch Kit Woes... Nightrain Ranger & B-Series 0 07-01-2009 04:42 AM
Tags
1994, 5th, 94, 97, cluch, clutch, fluid, ford, gear, loseing, problem, problems, ranger, slipping, troubleshoot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
