1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05 F350 6.0L Diesel, Cold Morning Starting
Old 01-06-2011, 11:08 AM
wogdiml's Avatar
wogdiml
wogdiml is offline
Just the last couple of weeks I've had to keep this truck's block heater plugged in for a longer period of time to get it to start. Last year it would start in the same cold temps, but this year it is acting like an older truck. One morning with about -10 degrees and only an hour of block heater it only turned over a couple of times and then clicked like it had dead batteries. I started it later that day with a battery boost and leaving it plugged in about 6 hours. I had NAPA put a battery tester on it and both tested ok with good voltage. I got around 13 on both batteries for voltage after it had started and run a while, I didn't test it before it was started. If I leave it plugged in 3-4 hours early morning it will start but still turns over hard (turns over slow). Temps have hovered around -5. I had the FICM replaced last fall so this is starting to feel like aging batteries on their last legs but I thought I'd see if anybody had any other thoughts or similar experience? The truck is a 2005 bought in Oct. 2005. It still has 15-40 oil in from last fall since I don't put much mileage on it. I have not added any diesel additive at this point.
Old 01-06-2011, 11:44 AM
gearloose1's Avatar
gearloose1
gearloose1 is offline
Detail how NAPA tested the batteries?
What is max voltage you are getting after 20 min running and idle at 2,000 rpm?
What is voltage sitting still in the morning?
What is voltage at cranking (with glow plugs on)?
Old 01-06-2011, 01:12 PM
wogdiml's Avatar
wogdiml
wogdiml is offline
Originally Posted by gearloose1
Detail how NAPA tested the batteries? HANDHELD BATTERY TESTER WITH + AND - CLAMPS. BATTERIES ON TRUCK, KEY OFF.
What is max voltage you are getting after 20 min running and idle at 2,000 rpm? 14.48 & 14.45
What is voltage sitting still in the morning? 12.36 & 12.35
What is voltage at cranking (with glow plugs on)? 11.39 & 11.42 (GLOW PLUGS ON ONLY, TRUCK NOT CRANKING SINCE I WAS BY MYSELF)
Thanks for your help.
Old 01-06-2011, 02:12 PM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Batteries lose capacity as they get older. Batteries also lose capacity as it gets colder. At -10F you may be down 75% of warm weather capacity. Old and cold is a double whammy.
Your batteries might test OK at quick parts store test, but still not have enough power to crank your engine on a very cold morning.
Old 01-06-2011, 02:21 PM
Fishin76's Avatar
Fishin76
Fishin76 is offline
regardless of the cold, you should have 12.8v. You have to disconnect the positive batt cable to test each batt independently. You may only have one bad batt.
Old 01-06-2011, 02:51 PM
gearloose1's Avatar
gearloose1
If the NAPA guy did not disconnect the two batteries and load test them separately, they did not do it right.
Do the voltage test with a helper at the coldest point in the morning before the engine is run --- If you are below 10V with glow plugs on and everything cranking... let me know.
Right now, I suspect batteries, but not alternator...
Old 01-07-2011, 12:02 PM
wogdiml's Avatar
wogdiml
wogdiml is offline
Voltage while cranking was 9.93.
I didn't think about the batteries being wired together while they were being tested at NAPA. I need to disconnect and retest to narrow this down to each battery.
whitelightning7.3
46
01-05-2023 03:53 PM
River19
19
02-22-2017 04:51 PM
F250_
18
01-12-2016 07:22 AM
RustOrBust
12-02-2014 11:56 PM
borealak
30
12-18-2010 01:50 PM
Quick Reply: 05 F350 6.0L Diesel, Cold Morning Starting
