repaced one IWE
repaced one IWE
OK, so I replace the drivers side IWE tonight. (was a pretty easy job btw) but I still have the grinding when I put the truck in 4X4. I did notice while i had the truck up and was changing the IWE that when I turned the wheel I could hear a clanking up higher where it connects up. what other 4x4 componets are up there. What should I look into next?
2005 ford F150 crew cab. 5.4L
CV joint?
If you have the front of the truck jacked up and turn the truck on, then spin each front wheel, does the halfshafts spin with the wheel? They shouldnt if your IWE system is working correctly.
Does the "clanking" occur no matter what while you have the 4WD on, or is it only at certain RPMS, or speed, or gear?
Might be the CV, but also if the IWE system is working correctly and in 2WD, with the truck running, and front jacked up, if you spin the tire the half shaft should not spin with it. If it does then something in the IWE system is still not working correctly. And until the IWE system is fixed and working correctly, you can not rule out that clanking isnt the IWEs. I would read my thread about the IWE, get a vacuum guage and start testing everything, get the IWE system working properly. Once that is done then see if you have the clanking still. At that point then you might want to check out your CV joints (unless you can physically see a problem with the CV)
But still if your telling me the halfshaft is spinning with the wheel in 2WD then something else is not right with the IWE system.
Here is the link to the thread.
https://www.ford-trucks.com/forums/8...then-some.html
I didnt have the truck running so of course the halfshaft spun when i spun the tire. I looked at the CV joints and nothing was obvious. I did stop by the stealership and they think it could be the transfer case??? But they cant really take a look at it until Wed. And at $80 an hour. I believe the IWE system is functioning correctly as the 4x4 does engage and all 4 tires do spin hust the nasy noise which seems to be coming from directly in the middle of the front end.
dealer
Well I dropped of my truck at the dealership this morning to find out what is going on with the 4 wheel drive. I wanted to post what I have learned because there seem to be a lot that are having 4X4 issues.
I had already replaced the IWE actuator on the drivers side which made no difference. Dealership gave me this description over the phone and my truck will be ready tomorrow. They said the pinion was coming out of the rear of the differential from a worn bearing or bushing. All they have to do is replace this bushing or bearing and tighten everything back up and Im ready to go. Under $200 fix.
Oh they also said I did a good job on the actuator replacement.
