FPHE + poly + sawzall = PICS of carnage!! - Ford Truck Enthusiasts Forums
Old 01-06-2011, 07:41 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Just staying honest folks. I always say 'or post pics...', well here they are.
This FPHE has been in truck for about 60k miles. Most of these miles are on the highway pulling 5th wheel. I see 190* to over 200* VO after the FPHE which is just before the heads. I think this poly problem started during the 1.5 yrs I used almost exclusively B100 in the diesel tank. After one trip where I went 10k miles on a single tank of B100 - I started plugging diesel filters with poly and the failed lining of my diesel tank. No more B100 and eventually started seeing more than a few 1000 miles out of a D2 filter (recently had tank re-lined so should be back to normal...). After over a year of no bio-d, I ended up rebuilding the engine and found the heads and injectors filled with poly flakes. These 'flakes' (looked like brown confetti) were packed into all the nooks and crannies in the fuel rails.
I think that every nite when I purged the VO out of the heads with (aged and COOKED) B100, the B100 polymerized in the carbon steel heads and formed a thin layer of poly. Then, when the truck was started a few hours later, 60-80psi of fuel pressure pushed the 'skin' into the corners. The bigger problem is likely due to the poly flakes that were pushed back into the FPHE when I was purging. During this time, a MUCH larger volume of fuel is gushed thru the heads than even when engine is running at WOT. Some of these flakes were washed loose from their mooring and made it out of heads - first to the FPHE, but some even made it to VO tank (I found it in my VO pre-pump filter).
Add another year of use on the FPHE and I think the poly just stacked up. The final straw was coming home with no VO and diesel tank jacked up with poly and failed lining - so I turned heat off to VO system and ran about 60gals of diesel thru VO tank. I had a sight glass filter/screen thingy after FPHE because I was afraid there might be some flakes in there... Well, for several 1000 miles, there was NOTHING, but after that trip on diesel:
This is after 10mic fuel filter, 5ft of TIH and the FPHE. It all came out of FPHE...
I shared this on the VO forums I visit, but thought some of y'all might enjoy the pics as well.
Old 01-06-2011, 10:24 PM
bradyracing bradyracing is offline
bradyracing is starting off with a positive reputation.
Bio will float the lining on late model steel tanks with a lining. Are you sure you don't have VO somehow being returned to your bio/d2 tank. I've run bio for over 100k just on one engine and have never seen anything close to that.
Old 01-07-2011, 08:24 AM
Quote:
There has never been even a drop of VO in my diesel system. My problem with bio-d was most likely due to the extended time it spent in my diesel tank. Although the B100 was pretty 'fresh' when I put it in my tank, I drove as far as 10,000 miles on a single tank of it. During this time, the B100 in my diesel filter was COOKED for 12, 14, 16 hrs or more per day as I drove across the country flogging my PSD pulling my 5ver - while burning SVO (thru a separate fuel systems).
The failed tank lining was probably inevitable, but the polymerization in the diesel tank, fuel filter, heads (and FPHE) may have been avoided if ALL I used was B100.
The key ingredients to polymerization - the natural enemy of VO - include: TIME, HEAT, exposure to OXIDANTS and OXYGEN. In our case, some time has passed in the fryer (big variable here) and in the dumpster/drum/etc. The heat varies depending on processing for VO and bio-d, but LESS is better. The major oxidant is copper - nobody should expose their VO to copper, EVER - but carbon steel is 2nd for reactivity. Oxygen is easily added by sloshing fuel in the tank, but for example if you are using a spinner-type centrifuge (OC-20/50) - you are adding copious amounts of oxygen (and heat!).
My latest veggie conversion - best yet? SkySkiJason Bio-diesel, Propane & Alternative Diesel Engine Fuels 21 02-04-2016 02:54 PM
Another awesome 'custom' veggie conversion - 7.3 PSD SkySkiJason Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 09-18-2015 10:35 AM
Pre-pump filter SkySkiJason Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 04-27-2014 10:31 AM
Fixed - Marinco mod SkySkiJason 1999 - 2003 7.3L Power Stroke Diesel 28 10-30-2012 11:38 AM
Got any VO to spare? SkySkiJason Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 10-05-2008 12:43 PM
Tags
73, carnage, diesel, filter, fphe, frybrid, pics, poly, powerstroke, problems, running, sawzall, top, truck, zall
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
