Blue Devil Head Gasket Sealant???? - Ford Truck Enthusiasts Forums
Old 01-06-2011, 07:29 PM
mr.fordneck's Avatar
mr.fordneck mr.fordneck is offline
mr.fordneck is starting off with a positive reputation.
I have a 90 302 with a blown head gasket (milky oil, some smoke). Anyhow, I heard about this product but was skeptical about it. Has anyone used this before and if so how did it work out? Should I try it? I have money to replace the gasket but am throwing down a lot for a new diff so I don't want to spend a lot more.
Old 01-06-2011, 07:49 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
nflfreak43 has a good reputation on FTE.nflfreak43 has a good reputation on FTE.
just fix it yourself, a 1 maybe 2 weekend job depending on some things, bout 120 bucks for parts and supplies and your good...
Old 01-06-2011, 09:01 PM
Hotshot869's Avatar
Hotshot869 Hotshot869 is offline
Hotshot869 is starting off with a positive reputation.
yeah dude, just repair the head gasket yourself, if you keep at it, it can be done and driving within 2-3 days or if your a trooper 1-2. ^_^ don't use head gasket sealant because the head gasket is already blown.
Old 01-06-2011, 09:32 PM
CJM8515 CJM8515 is offline
CJM8515 is starting off with a positive reputation.
snake oil, it dont work.
Old 01-06-2011, 10:11 PM
kevin206's Avatar
kevin206 kevin206 is offline
kevin206 is starting off with a positive reputation.
Quote:
I have a mechanic friend with a blown head gasket on his aerostar. He thought he would give that stuff a try for the $50 or so it cost. He tried it, it didn't work. He called customer support, They asked if he followed the directions EXACTLY. He followed them pretty close, but not exactly. They sent him out another can and said that it was very important to follow the directions EXACTLY. He tried again and followed the directions exactly. It worked! That's been about two years ago. He keeps driving it but knows that it needs to be fixed correctly. I think a valve seat or something got taken out when the gasket blew. He keeps running it with one dead cylinder.
Old 01-06-2011, 10:25 PM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
I wouldn't use it unless time and/or money was a factor. Even if the product works, you are runing on borrowed time. Worse case scenario is you damage more in the long run.
I agree with others' concerns.
Old 01-06-2011, 10:48 PM
Is that a hard job. I've never repaired anything that in depth before plus its EFI so I'm worried bout breaking something but I don't wanna pay my mechanic a grand to do it
Old 01-07-2011, 12:33 AM
If you can determine which head it is, you will be in better shape. If it's the driver side head, it's easier to get at than the passenger side. Either way you will have to remove the intake, manifold, valve covers, the AC, alt. If you have 1-3 days to do the work, it's far cheaper. If not, call around several shops to get an estimate for repair.
Old 01-07-2011, 04:34 AM
Hotshot869's Avatar
it really isn't "hard" but it's time consuming and you MUST! MUST MUST MUST!!!! keep everything in order as to where it goes, get lil baggies and label EVERYTHING! haha no joke. we repaired my friends 350 head gasket and he didn't keep order...hell of a time trying to fix everything..anyways, like timbersteel said, you will have to completely remove the head, so the intake, valve covers, AC, Alt, Plenum, all must go. if you can figure out which side is blown, it'll be a ton more easier. just remember you got this, it's nothing major hard, just time consuming. take it slow and you'll be fine
Old 01-07-2011, 07:28 AM
nflfreak43's Avatar
biggest thing is to keep track of everything. thats a huge role in this..
Old 01-07-2011, 11:32 AM
Quote:
And that there is why its snake oil
Old 01-07-2011, 12:07 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Replace both head gaskets while its apart , you don't want to do it again , ..
312 Y block head gasket? Tomget 1957 - 1960 F100 & Larger F-Series Trucks 5 04-18-2015 06:45 PM
Head Gasket job Question Beast_Mode_13 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 05-24-2013 09:36 AM
Intake Gasket Trim?? LFDavidson FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 08-27-2009 08:39 PM
using shim head gaskets fordeverpower FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 07-24-2008 02:25 PM
2001 Super Crew - 5.4 Oil Leak John_1953 1997 - 2003 F150 1 04-03-2008 02:26 PM
Tags
60, 69l, blue, compatible, devil, diesel, directions, flat, ford, gasket, head, oil, repair, reviews, sealant, snake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
