hood installed on my 51
Old 01-06-2011, 10:52 AM
arrowheadfred's Avatar
arrowheadfred
arrowheadfred is offline
I got the hood on but the back don't want to go down. I have to push it with my hand . IT FITS GOOD . What the trouble with it ?
Old 01-06-2011, 10:57 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
The issue is almost likely with the "two finger" hood side brackets that are mounted on the sides of the cab/cowl. They need to be adjusted. Try loosening them from the inside of the cab and see how your hood closes with the hinges being slightly loose. Retighten them while the hood is closed.
That's how I made the adjustment in my 52.
Old 01-06-2011, 01:31 PM
arrowheadfred
hinges
I hope i didn't mess these hinges up. I saw that they had alot of lose play so before i painted them i used a hammer to tighten them up. They still moved freely but took the slope out of them. SO just how much play should they have ?
Old 01-06-2011, 02:46 PM
51PanelMan's Avatar
51PanelMan
Here's the profile shot.
Side shot.
Not sure where you tightened them up, but you probably you have left them alone. If they still have the same shape as in my pictures, then try adjusting them like I described.
If you need another set, then I may have a pair laying around.
Old 01-06-2011, 03:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I think Fred means he took the slop out at the pins? Shouldn't be the problem. It's just a common issue on all old Fords. It helps to make sure the latch at front of hood is a little further out than you'd first think, so closing it tends to draw the hood forward a little.
Old 01-06-2011, 06:12 PM
KidShalene's Avatar
KidShalene
KidShalene is offline
Could be that you tightened them up a little too much and they're just in a bind that the springs can't overcome to fully close down.
Seeing that it does go into place when you push down the corners kinda makes me believe they may be too tight.
I was going to do the same to mine (hammer/anvil them tight), I'm now starting to consider this solution.
I think I'll try using some old feeler gauge strips to insert between the hinge arms and the bracket at the pin, maybe .005 or .010, then hammer/anvil it till I have a nice tight fit.
After removing the feeler gauge it should not be sloppy, but not real tight either.
Old 01-06-2011, 06:14 PM
arrowheadfred
can u see what i did
I took some pics. of the hood on and the hinge were i tighten it up.
Old 01-06-2011, 06:17 PM
KidShalene's Avatar
KidShalene
Could also be the paint gumming up the works....
Old 01-06-2011, 06:19 PM
arrowheadfred
another pic.
maybe you can see were i flaten the back of the pin out to tighten it up
Old 01-06-2011, 06:22 PM
KidShalene's Avatar
KidShalene
Which trim is going to be on your hood and when can we see pics of that?
Old 01-06-2011, 06:29 PM
arrowheadfred
ilya may be right
Hope ilya is right about loosening the in side bolts then closing the hood . LET YALL KNOW 2MOR.
Old 01-06-2011, 07:48 PM
homade's Avatar
homade
homade is offline
Before tightening the bolts inside in the kick panel, slightley push the hood back toward the windshield, seemed to help when I adjusted mine.
Old 01-06-2011, 08:06 PM
arrowheadfred
TRIM
I got the 51 5 star trim Mr. KID . Need to buff the truck before trim go's on. Was going to wait till i get it back from the upholstrey shop too buff it all down. Hope to take it monday for seat and stuff. CAN'T WAIT TO CRUZ THE COAST.
Old 01-06-2011, 08:59 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Looks great... each time you post pics it keeps looking better....
Old 01-06-2011, 09:07 PM
iwanaflattie's Avatar
iwanaflattie
iwanaflattie is offline
wo that looks great...
Quick Reply: hood installed on my 51
