I don't think Ford sells those parts, they make you buy the whole lamp assembly and junk yards usually won't split stuff like that up either. If you could get a hold of a good one you probably could make one from it if you can't find a used one
the plastic on the part that the long rod goes in to is kind of loose so it will not move the headlight what i turn the rod with a wrench i need to find a way to fix that with out using that dang rod. Has anyone ran in to this an fix it or went a different way.
