Power steering problem
Old 02-21-2013, 08:54 PM
1great40's Avatar
1great40
1great40 is offline
My 40 Ford pickup is on an 86 Ranger chassis and uses the stock Ranger steering gear. My question is about the connections on the steering box. I'm using a GM power steering pump and several steering gear vendors have told me that outside of needing to adjust the pressure for the correct feel, the combo works. I fired the truck for the first time tonight but the steering wheel went crazy, shaking around and finally spinning on it's own to a hard left. Some quick research leads me to believe that I have the lines reversed but it would be great to know for sure. I did manage to find on e diagram of a Ford PS box on Google and it shows the lines reversed of what I have set up on my truck and I can't for the life of me remember how I figured out what the plumbing should be when I installed it. Can anyone tell me which port on the box is the inlet and which is the return?
Old 02-22-2013, 12:15 PM
Rangerman Stan's Avatar
Rangerman Stan
Rangerman Stan is offline
The forward most port on the power steering box on my 91 Ranger is the pressure inlet. The stock line that goes there has a smaller size hex line nut than the return line which is larger. My 91 has an 86 gear box in it.
Old 02-22-2013, 02:28 PM
1great40's Avatar
1great40
1great40 is offline
Thanks
Thanks! I also managed to track down a diagram of a Ford box online last night that bears out what you said! I did a little creative plumbing today and got the lines turned around...Will fire it up later and see. I expect things to be fine.
Mike Bartlett
1999 to 2016 Super Duty
11-20-2017 11:28 PM
atomicjoe23
08-18-2009 07:31 PM
aayoakam
22
06-22-2005 09:00 PM
sigtauenus
13
08-31-2003 12:02 AM
Quick Reply: Power steering problem
