Ticking Noise. '98 5.4 164k
My truck has a ticking noise that has came, went and come back. Truck runs excellent.
It's a constant ticking that sound like a plug or injector on the left front of the engine. It speeds and slows with engine RPM, warm or cold. It's not very loud, but it's something. I have yet to check the plugs to see if any are loose. Oil level is good and clean. It seemed to develop out of no where for no reason. Any thoughts from experience to what this may be is appreciated.
FF
FF
You probably have a laminated exhaust gasket, and once they start to rust out, the smallest leak will cause a ticking noise. It's really hard to see sometimes, unless it blackens the head a little. Of the the ones I've seen/repaired, if it is an exhaust gasket leak, it's the loudest when the engine is cold, and lessens as it warms up.
Dave
Dave
FF
FF
Check them all, doubt it is exhaust.
