body to frame ground strap - Ford Truck Enthusiasts Forums
Old 01-05-2011, 07:44 PM
johaner78 johaner78 is offline
johaner78 is starting off with a positive reputation.
Does anybody know the part number for the body to frame ground strap used on our beloved trucks? What part of the frame and body does it mount to? Any pics of one?
Old 01-05-2011, 07:49 PM
650's Avatar
650 650 is offline
650 is starting off with a positive reputation.
I was thinking it went from about the bottom front right of the cab to the frame, though I could be wrong.
Old 01-05-2011, 08:43 PM
oem78 oem78 is offline
oem78 is starting off with a positive reputation.
Ground straps
My 1979 has six ground straps, I dont' know if they are factory, they look like they have been on the truck a long time. Below each headlight under the front aprons attached to the frame,behind the front wheels by the cab/door area frame to cab attachments, front of the bed to the frame behind the drivers side cab, and one on the firewall to the engine block.
I'll try to find the part number.
Old 01-05-2011, 08:53 PM
oem78 i was thinking about the strap from the cab to the frame under the right side. Doesn't the box ground itself to the frame via the box mounting bolts?? I have the ground strap from the engine to the firewall and the engine will be grounded to the battery. I think all i need now is the cab to frame strap but would like to find an OEM one and know where it needs to attach to.
Ground straps newguy399 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-24-2016 09:05 PM
Grounding Straps/Wires--How Many? kindorotten 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-21-2016 11:18 AM
Electrical Q's: Ground(s) jhl3 1999 - 2003 7.3L Power Stroke Diesel 15 07-26-2016 04:37 PM
Grounding and where to put the wires Order and Chaos 1961 - 1966 F-100 & Larger F-Series Trucks 6 10-24-2015 05:45 AM
Ground strap: Body to Frame Eric H 1999 - 2003 7.3L Power Stroke Diesel 1 09-26-2009 07:10 PM
Tags
08, 2010, block, body, cab, engine, f150, ford, frame, ground, grounding, grounds, location, locations, strap, straps, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
