Looking to put 4.10s in my '07 5.4L 2wd - opinions needed
I have an '07 F150 supercab with a 6.5' bed, 2wd with a 5.4. It currently has the standard 3.55 gear with a 245/70 R 17 tire. I pull a trailer pretty frequently and can tell that it's geared just a tad too high in its current form. If I was going to stick with this size wheel and tire, I'd probably just switch to a 3.73, however I intend to put a 20" wheel on it and run a 275/60 R20 or a 285/50 R20 tire. I'm thinking I would be better off with a 4.10 gear with that combination. Has anyone on here had a similar combination with a 4.10 gear? I'm curious about the "real feel" after you installed the 4.10s. I'm also curious about the effects it might have on the fuel economy. Anyone?
Thanks for the input. I suspected there might be a slight increase in gas mileage noted, especially when pulling a load.
fordboy97
13
03-22-2015 09:15 PM
ADVNTURR
13
07-26-2012 09:47 PM
fordmanva
03-13-2012 09:23 PM
96fourbanger
11-24-2004 05:12 PM
