What does the Ignition Control Module do? - Ford Truck Enthusiasts Forums
Old 01-05-2011, 05:58 PM
jv2290's Avatar
jv2290 jv2290 is offline
jv2290 is starting off with a positive reputation.
I have a 1992 F250 with a 5.0 & E4OD transmission. I've been having issues with starting it and I think it's the ICM. The ICM is the fender mount style, gray in color and the number on it is E7DF-12A297-A1A. My question is, what exactly does the ICM do? Are there anyways to test it? I've seen people post that they had them tested and they passed but were still bad. My truck has a very hard time starting only when it's cold out. It was 55 Fahrenheit outside the other day and it started decent. any temp above 65 it'll start great! When it's cold out it runs like crap until it warms up. It acts like it's on 2 cylinders. But once it warms up it's great! I've changed lots such as ECT, O2, IAC, plugs, wires, cap, rotor, coil, exhaust, air filter, TPS, EGR system, and the fuel system tested fine and the parts are new anyway including the filter. It acts like the coil is cutting out and the timing doesn't wanna sit still much. The idle changes randomly and I believe it's because of the timing moving around. I even believe I hear labor knocks / pings as is the timing is too high. I already advanced it and now turned it back down to 10* and still hear sometimes. Is this what the ICM does? I would really like to know EXACTLY what the ICM does just for reference reasons. Thanks In Advance!!
** Forgot to say that I checked for codes and KOEO I get 111 and sometime 625, and then continuous 512, KOER I get 111.
Old 01-05-2011, 08:19 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
You may have the wrong ICM installed. It should be black in color. Take a look at post#9 in this thread: http://www.ford-trucks.com/forums/10...-stranded.html
Some good reading here on ICMs: http://www.msextra.com/doc/ms1extra/...n-tfi-edit.doc
Old 01-05-2011, 09:04 PM
jv2290's Avatar
I actually believe it's the original one. I've had it in there for the 4 years I've owned it. It was on the truck wneh I bought it. I never had these issues before. But thanks for that info! I'll check it out.
Old 01-05-2011, 10:56 PM
jv2290's Avatar
The last link didn't work
Old 01-06-2011, 12:49 AM
planehunter's Avatar
planehunter planehunter is offline
planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.
Ford ICM are very corrosion sensitive. Maybe you have a bad connection, or a crack in a connector affecting contact.
Old 01-06-2011, 12:54 AM
deeznuts822's Avatar
deeznuts822 deeznuts822 is offline
deeznuts822 is starting off with a positive reputation.
You could have a bad engine coolant sensor by the thermostat being that its temp related.
Old 01-06-2011, 01:05 AM
jv2290's Avatar
Coolant sensors are new. I'm wondering if it's a dirty connection at the PCM. I just didn't know if the ICM is what controls the spark and timing. It seems like the coil cuts off. Strange thing is if I take off the starter relay wire and hold it in start it runs great! So I don't know haha
Old 01-06-2011, 07:49 AM
rla2005's Avatar
I did a little more research, I do stand corrected. The correct ICM would be the gray Push-start version. The Black CCD version is for 1994+ trucks.
I apologize for leading astray on the subject.
Old 01-06-2011, 07:52 AM
rla2005's Avatar
Try this: Index of /doc/ms1extra/MS_Extra_Hardware_Manual_files
Then scroll down and select "ford-Ignition-tfi-edit.doc"
93 Ranger 2.3L won't start, CPS/ICM Grampa50 Ranger & B-Series 0 01-26-2017 04:31 PM
Need advice about ignition issue Bill2012 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-31-2015 12:15 PM
93 ranger sport 4x4 w/2.3L no start problem wp23n Ranger & B-Series 6 12-28-2012 04:59 PM
Please help! 75 engine. ignition troubles mudder_lover 1973 - 1979 F-100 & Larger F-Series Trucks 29 05-04-2011 08:59 PM
My 1995 F150 has lost it's spark jrb412 1987 - 1996 F150 & Larger F-Series Trucks 12 11-05-2010 03:15 PM
Tags
1987, 1992, 46, 92, control, f150, fender, ford, icm, ignition, liter, module, mount, triton, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
