Winter grill cover - Ford Truck Enthusiasts Forums
Winter grill cover
Old 01-05-2011, 06:56 PM
SixStringMadness's Avatar
SixStringMadness SixStringMadness is offline
SixStringMadness is gaining momentum as a positive member of FTE.
Winter grill cover
Have any of you guys been able to find and use, of do any of you know where to find a winter grill cover fitted for the Superduty grill. I understand I can get a "fits all makes" but I would prefer to use one fitted to the truck. Any thoughts?
Old 01-05-2011, 07:10 PM
bradyracing bradyracing is offline
bradyracing is starting off with a positive reputation.
I bought one off of ebay for the 99-04 grill for 70 bucks. I think the Cabela's catalog has them in there too.
Old 01-05-2011, 07:36 PM
Rob.D's Avatar
Rob.D Rob.D is offline
Rob.D is starting off with a positive reputation.
I've been using the one from Cabela's. Works great, however I bought an extra grill so I don't have to look at the snaps all summer.
Old 01-05-2011, 07:49 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
hmmmm. cardboad slats from time to time. there one time adjustable too.
Old 01-05-2011, 08:38 PM
I've seen the one for the 08 - 10 model trucks. Has a big Ford logo, and no snaps to drill. An OEM part. I would think I could at least find a picture on the internet of one sitting on a 99 - 04 grill..... nothing. I want to see a picture of one of these non OEM covers before I buy it. I can't believe how difficult this is to find.
Old 01-05-2011, 08:41 PM
Quote:
Problem with that is, under the hood I have to remove the cover that covers access to the piece I want to cover (external oil cooler). If I get a warm day, I don't want to stop on the side of the road and spend 20 minutes to remove it just to get to a solid board of some sort when I could just undo a few velcro straps, and get on with it.
Old 01-05-2011, 08:43 PM
djanzen's Avatar
djanzen djanzen is offline
djanzen is gaining momentum as a positive member of FTE.djanzen is gaining momentum as a positive member of FTE.
they slide nicely between the ac condenser and rad
Old 01-05-2011, 08:54 PM
Quote:
again, you have to remove the cover to get to that, as that is exactly where my oil cooler is now. I'd rather it be on the outside of the grill
Old 01-05-2011, 09:59 PM
DPorter DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
GoFia.com - Step 1
This is what I have on mine.
Old 01-05-2011, 10:40 PM
That's the one I have, Fia.
Old 01-05-2011, 11:59 PM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
Quote:
Originally Posted by DPorter View Post
GoFia.com - Step 1
How much was it?
Old 01-06-2011, 01:31 AM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
I do the same thing but I use some plastic panels when I take it into the colder climates.
I put it behind the ac radiator.
Old 01-06-2011, 05:57 AM
they are about $70.00 + tax and shipping.
Old 01-06-2011, 07:36 AM
foul1 foul1 is offline
foul1 is starting off with a positive reputation.
If you slide underneath the trk u will not need to remove anything just pull off a couple of clips holding a rubber strip inbetween the radiators. their similiar to what holds on interior door panels. slide the cardboard in.
Old 01-06-2011, 07:46 AM
Rob.D's Avatar
GoFia.com - Step 1
Looks identical to the one I have from Cabelas.
Winter grill cover kefrko 1999 - 2003 7.3L Power Stroke Diesel 38 02-09-2014 10:34 AM
grill cover barnhartred 1999 - 2003 7.3L Power Stroke Diesel 14 12-14-2013 10:19 PM
Winter Front Andrew010 6.7L Power Stroke Diesel 17 11-27-2011 02:25 PM
Looking for winter grill cover waumpuscat 6.0L Power Stroke Diesel 2 11-12-2011 01:25 PM
Winter Grill cover 5. Slow 1994.5 - 1997 7.3L Power Stroke Diesel 21 01-07-2011 12:17 AM
Tags
2008, 2010, 350, 60, cover, covers, diesal, diesel, f250, ford, grill, grille, install, installing, powerstroke, superduty, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
