To all 3.0L FFV owners
Old 03-06-2003, 06:18 AM
Bob Ayers's Avatar
Bob Ayers
Bob Ayers is offline
If you own a 3.0L FFV, are you aware that Ford no longer carries
the correct plug for your truck???? The correct plug is AGSF12PP,
and they will try and sell you a AGSF22PP. The AGSF22PP is the
plug for the 4.0L, and is TOO HOT for the 3.0L FFV. This is a ploy
by the "bean counters" at Ford to reduce inventory cost. I have tried
the AGSF22PP plugs, and my MPG dropped, and I had a rough idle.
Luckily I was able to find a set of AGSF12PP plugs, my idle is
smooth again, and my MPG is back up!!!
Please call 1-800-258-3673 and complain about what Ford has done, and
request Ford to start production again on the AGSF12PP plugs!!!
Old 03-06-2003, 05:33 PM
bobby's friend's Avatar
bobby's friend
bobby's friend is offline
Bobby still flogging that dead cat? Nice touch "ex-RPS user" lol
Old 03-07-2003, 05:26 AM
Bob Ayers's Avatar
Bob Ayers
It's "Ex RPS poster", not "Ex RPS user" ......
Old 03-07-2003, 08:31 AM
bobby's friend
My truck runs fine with AGSF22PP's so maybe it's just your truck that has the problem.
Old 03-10-2003, 05:14 PM
black wolf's Avatar
black wolf
black wolf is offline
hey Bob thanks for the tip!!! i will let my friends know about this just in case..i just got rid of the champion plugs out of my 4.0 and put in motorcraft where it belongs and yes i did check a few weeks ago to make sure i had the right plugs as i was leary too..whew they were the right ones..
Old 03-11-2003, 08:39 AM
WXboy's Avatar
WXboy
WXboy is offline
Not to mention that Ford wanted $223.00 to change the plugs and wires on my 4.0! They wanted $7.00 each for the plugs.
NO THANKS.
So I bought Bosch Platinum 2 plugs for half the price at the store, and did the tune up myself for $75 (including a new fuel filter). Now my fuel mileage is up just a tad, and the truck runs much smoother and quieter too.
The moral: Motorcraft parts, and esp. from the dealer, is not always the way to go.
Old 03-11-2003, 09:41 AM
Bob Ayers's Avatar
Bob Ayers
You can get Motorcraft double platinums for your 4.0L at
Autozone for $3.99. With the Bosch plugs, only the center
electrode is platinum, so only the plugs in one bank will last.
With Ford's EDIS, the plugs in one back get the negative portion
of the spark, so the GND electrode will erode. It was my experience, and I have heard others also, say the Bosch plugs
run TOO HOT!!!
Old 03-11-2003, 01:29 PM
WXboy's Avatar
WXboy
WXboy is offline
Bob...so basically the dealers are just marking parts up and getting huge profits on them, and then they hit you with labor? Hmmm....
Old 03-11-2003, 01:32 PM
Bob Ayers's Avatar
Bob Ayers
Yes, I think you have hit the nail on the head!!!!
B.T.W. , how did you make out changing your oil pressure
sending unit??????
Old 03-12-2003, 10:59 AM
WXboy's Avatar
WXboy
WXboy is offline
Bob... I haven't tried the oil pressure sending unit just yet. I haven't had enough time to crawl under the truck and locate where my sending unit is. Also, I'm still trying to decide whether or not I want to take on the project, because there is more envolved than I thought. But if I do it I will let you know the result. I do appreciate your help...it was all very good info.
And, you say the Bosch plugs are TOO HOT for my 4.0L. If this was the case, wouldn't I see a drop in fuel mileage? I haven't checked it yet...still on the first tank since the tune-up, but I think I'm doing the same or a tad better on fuel so far.
Old 06-08-2003, 09:04 AM
XLTdav's Avatar
XLTdav
XLTdav is offline
OK i have the 3.0 flex and i wanted to know if there are any aftermarket sparkplugs that are good i was just lookin at autolights double plats anyone know if they are good?
Old 06-08-2003, 09:12 AM
Bob Ayers's Avatar
Bob Ayers
Autolites, and Motorcrafts are both made by Honeywell. If you
can find the Autolite equivalent to a Motorcraft AGSF12PP, they
will run great in your 3.0L FFV
Old 06-08-2003, 09:18 AM
XLTdav's Avatar
XLTdav
XLTdav is offline
Ok how in the heck will i know that i just know the part # there catalog tells me
Old 06-08-2003, 09:29 AM
Bob Ayers's Avatar
Bob Ayers
The Autolite website is calling for a APP103. I believe this is
equivalent to a Motorcraft AGSF22PP. You will want to go with
1 heat range colder than the APP103.
Old 06-08-2003, 10:35 AM
01RangerSC's Avatar
01RangerSC
01RangerSC is offline
Beware of interchanging spark plugs from one brand to the other. They will list in some catalogs that plug"x" replaces plug"b" but look in plug "b"'s book and plug "a" replaces something else. Stick with the Motorcraft and you'll be fine. One heat range usually will not make that much difference.
Quick Reply: To all 3.0L FFV owners
