2006 5.4 wont start - Ford Truck Enthusiasts Forums
2006 5.4 wont start
Old 01-05-2011, 12:28 PM
bobbyt89 bobbyt89 is offline
bobbyt89 is starting off with a positive reputation.
2006 5.4 wont start
i was driving my 2006 f150 with a 5.4 3 days ago went around the block and it died on me. cant figure out whats wrong it shows a p0191 code i think. It was a fuel rail pressure code i replaced the filter and still nothing any ideas suggestions? i will say i used a sea foamintake foging spray to clean it did it wile it was on like it says to shutit off waited like 20 mins and drive home.it was off for 30 and then i went to leave made it 300 yards and it diedplease help
Old 01-05-2011, 01:38 PM
floydwall's Avatar
floydwall floydwall is offline
floydwall is starting off with a positive reputation.
You pull a plug and see what it looked like?
Old 01-05-2011, 07:44 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
My best guess would be either fuel pump or fuel pump driver module. Run the diagnostic routine for that code and you'll find the culprit. Pump is in the tank and the driver module is on the crossmember in front of the spare tire. But it's probably one or the other.
Old 01-08-2011, 12:01 AM
dont know it this helps but the #9 fuse was blown and still wont start when replaced
Old 01-08-2011, 02:06 AM
mattsautobody442's Avatar
mattsautobody442 mattsautobody442 is offline
mattsautobody442 is starting off with a positive reputation.
same thing happened to me today.... repalced the fuel filter ten thousand miles ago
2006 Ford f150 Kingranch 5.4 p0430/p0420 code help plz!! ckellis89 2004 - 2008 F150 4 04-05-2016 07:16 PM
5.4 Intake runner valve stuck 67highboy 1999 to 2016 Super Duty 1 05-06-2015 06:52 AM
2006 f150 5.4 starting problem Revor1985 Modular V8 (4.6L, 5.4L) 3 11-09-2011 06:55 AM
please help sustanetti Modular V8 (4.6L, 5.4L) 14 11-06-2009 07:03 AM
2006 5.4 no throttle response hankijb 2004 - 2008 F150 1 01-27-2008 05:54 PM
Tags
04, 06, 2006, 2007, 54, code, engine, f150, f250, ford, motor, p0191, p1237, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
