97 expy worth changing to PI heads
Hey genius do some homework the PI swap raises comp to 11:1 lemme know how 87 octane works out on that. If your doin any type of performance work on an engine tuning for premium fuel is a no brainer and where I come from I self tuned my fuel injected race car to run on c-16 I understand the characteristics of higher octane fuels they allow a much more forgiving tuning window and much more aggressive timing. Has anyone on here ever dynoed anything? Sorry guys you don't shoot for a performance " balance" in the aftermarket hp world. Yeah and I bet a comeback will be (if someone is sharp enough to notice) that the 11 gt is 11:1comp but our trucks do not have TIVCT or a hemi style comb chamber or piston cooling jets or any of the 15 year newer pcm tech that allows this. And at $85-90 to fill my tank on 87 wtf difference is $6 more gonna make for a 50 hp increase on a truck I drive 5-7k a year ....yeah im bragging about running "premium" fuel....he'll I should fill up on my $16.20 a gallon c- 16 and ill make another 100hp!!! Gimmie a break ill go back to the corral and ask this and see if I can get someone who is able to do more than install a k&n filter and brag about your last bolt on that took 2 hours to install but you got 40 hp from it.....peace
I certainly don't need to add much to that!!! Good job.
To start, I use this online-calculator to calculate static compression ratios:
RSR Static Compression Ratio Calculator
using these specs:
- Bore= 3.552"
- Stroke= 4.165"
- HeadGasket= 0.036"
- Deck Height= 0.112"
- Piston dish= 10.49cc
- Combustion chamber= 50cc
you end up with the stock 9:1 static CR for stock 5.4 NPI motor. Drop the combustion chamber to 42cc from the PI head, and you end up with 9.8:1. So almost (or should I say only) 10:1, but no where near 11:1. Now on passenger cars, like mustangs, Tbirds/Cougars, crown-vics, etc, due to the differences in deck height (0.012 vs 0.112) and stroke (3.543 vs 4.165), the CR does indeed go up higher; but even then its 10.54:1, so still not 11:1 unless you shave the heads a significant amount.
So for the most part, the stock timing tables are conservative enough and the resulting CR is low enough that a PI head swap doesn't necessitate the need for premium fuel; the exceptions being normal carbon buildup in the combustion chambers, or perhaps some timing table changes in the different calibrations that get released over the years. This is why some people have good luck running 87 octane, but others end up needing mid-grade or premium to curb the pinging after a PI head swap. Either way, the compression bump is worth it IMO, as it is the basis for a high-powered modular motor; they love compression.
As far as getting over 300 BHP naturally aspirated out of a 2V 5.4, you can forget about it if you plan to keep the stock intake manifold. The runners are skinny and very l o n g, because that is what allows the torque to build up earliet to get these heavy vehicles up and moving--and thats the exact opposite of what you need for upper-RPM power; ideally you want FAT and SHORT runners. The stock intake just doesn't lend itself to shifting the powerband up high, like the way the PI intake allows on the passenger cars. More compression will bring up both the torque & HP curves at all points, but once you try to shift the powerband up higher, you just see a very disappointing plateau at higher RPMs where the manifold is choking for air and holding everything back, no matter what cams or exhaust you have. You'd need something like this:
ModularHeadShop 5.4 2V intake page
or like mine (but for a 5.4 truck which are available):
either way, you're looking at top-dollar stuff to make lots of N/A power of a 5.4 2V motor.
See now that's an itelligent answer now the truck will wear a full exhaust and I will dyno tune to see what see what we end up with. Im figuring with the PI swap I can put the motor around 270-275 fwhp a full exhaust (+10-15hp) and a tune I can get real close to 300 fwhp not rwhp. So let's say I out down 240 at the tire and 300 tq that to me would be impressive on this motor and def not out of reach. Great info though thanks a ton. Wish you had answered first. As far as the pushrod motor you got ...I can help ya on that had a fox for 15 years and went from stock (14.80s) to now 9.50s on only 150 shot with another 300 on board for when its dialed in. Thanks again and ill PM ya if I have some detailed questions along the way
No need to go to the "corral", lol. I've done the PI cam swap, PI head swap, aftermarket cam swap, intake manifold swap, injectors, maf, custom tuning, etc. Granted I did none of this on my F150, it was on my 97 4.6 Cougar, but none the less, I can give you some real world experience.
using these specs:
using these specs:
- Bore= 3.552"
- Stroke= 4.165"
look at those prudy aftermarket intake manifolds, too bad BOTH WILL COST LOW END TORQUE
Luckily the laws of physics tell us that torque is not conserved, this it can be manipulated in ways hp cannot. If there is 10,000 ft-lbs at the wheels, external measurements cannot determine how much of that is due to engine torque, stall multiplication, or gearing.
What this spells out for people looking for N/A performance, is that hp production should take precedence, because torque at the wheels (which is what really matters), can be increased/decreased, most commonly through shorter gears. You can dial in pretty much any reasonable amount of torque after the engine produces what it can with available gearing. This is not possible with HP--whatcha got is whatcha got. Therefore for N/A performance, the HP should be built up, and any missing torque can be added back in via gearing, or maybe even a better converter with a greater K factor (multiplier).
