strange noise durring accelerating
#32
#33
Yeah, you're right. 03 Ford expo 5.4 EB. When accelerating hard or uphill around 2000 RPM noise would start, then stopped immediately once I left off accelerator. Popped it in 4H (immediately made same noise until engaged), no noise at same RPM's and conditions. I know this because mine has been doing for ssooooo long (a year) I could create the noise on demand. Do you know how much the vacuum leak cost to repair?
#34
This has happened about half a dozen times while accelerating. It sounds sort of like it's between a scratching noise and a rattling noise. It's only happened at highway speeds 50-60 mph while accelerating and will stop when i let off the gas. there have been a few times that i can get it to come back if i step on the throttle again, but will not duplicate every time. any ideas?
#35
#36
#37
#38
2011 f150 fx4 (5.0)
My truck has been making a rattling noise when I press the gas but goes right away when I let off I replaced the vacuum hose to the brakes like the dealer said it is still doing it I can't figure out whats the cause but in no way does it effect the truck towards speed it's just a noise in the front left wheel well area
#39
Crystal
#40
They said it could be the 4wd actuator but I wanted to see if anyone else was told that and I have 71,000 on it now
#41
Crystal
#42
have you inspected the check valve in that area as well? That is what was wrong with my truck all along. Sorry I didnt' update this thread, I started a new one explaining all of my symptoms and what fixed it.
The check valve is used to keep vacuum in the vacuum reservoir as well as keep vacuum to the IWE's (Integrated Wheel Ends) when vacuum drops off during acceleration. I thought mine was good when I first inspected it... when I sucked on one end or blew on the other it would seal...eventually. It took about a second to seal and took a good amount of pressure/ vacuum to do it. After buying a new one I could see the clear difference between the 2. the new one took no effort to seal vs the old one took quite a bit of press/vacuum to seal up. that is where the slow favuum leak was coming from allowing the iwe to start to engage when it wasnt' supposed to and produced the grinding noise.
Hope this helps,
Q.
Hope this helps,
Q.
#43
Alright .....I just got done having this exact problem with my truck after getting a tune up and tension pulleys replaced. Started making a sound like flapping sheet metal in the wind.....or a tape measure stretched out and it collapses is the best description. Only happened between 50 and 60 mph. Turns out it was a vacuum hose that was cracked going to the front hub lockers. It was explained to me that it is normally under pressure to keep it from being locked. It is at most pressure at freeway speeds, so with it leaking, the lack of pressure is trying to engage the lockers for 4WD but not all the way.....so the sound I was hearing was the gears rubbing against each other......the tech and I only discovered it when we were travelling at freeway speeds and engaged the 4WD on the fly.....in 4WD, when accelerating 30 to 60.....the sound was gone......disengaged the 4WD and the sound returned. When back at ford, the vacuum hose they found that was the problem was located just by the corner nearest the passenger side firewall....on my 2008 firewall behind the battery. They replaced the vacuum line and it fixed the metal noise I was hearing. Hope that helps because I, all my friends, and almost everyone at ford was going crazy trying to figure it out.
#44
Vacuum line
D8chumley: I have not found a fix yet. I do have a 4X4, have looked at front hubs(what i can see), don't see anything obvious and they don't have hub locks, lug nuts are tight, nothing in exhaust is loose or rattling. It's definitely not an exhaust noise, it is directly related to the accelerator. I've have a few people mention it being related to the vacuum system having a leak. Something about a small leak and when the engine is under a load, one of the front hubs is trying to engage. Not sure if that makes sense or not.
#45
