bleeding cooling system - Ford Truck Enthusiasts Forums
Old 01-11-2003, 01:10 PM
lawless lawless is offline
lawless is starting off with a positive reputation.
I just put a heater core in a 1989 E150 5.0l. I need to know how to bleed the cooling system. Thanks in advance.
Old 01-11-2003, 01:27 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Fill up the radiator, and then with the cap off, start the truck and turn the heater on. Let it warm up so that the thermostat opens up. Then add additional water/coolant as necessary to bring the level in the radiator back up to the filler neck.
Old 01-13-2003, 08:37 AM
billman billman is offline
billman is starting off with a positive reputation.
>filler neck.
When I try to do that with my 5.8, as it warms up, the coolant starts to come back out the rad cap. Is that a problem?
Old 01-13-2003, 09:43 AM
michaelskerrett michaelskerrett is offline
michaelskerrett is starting off with a positive reputation.
Post bleeding cooling system
No, its not a problem, but there is no sense in letting good coolent flow on the ground. I usually leave the cap on and wait until a few minutes after I feel the top hose get hot. This means that the coolent is flowing back to the engine due to the thermostat opening. Carefully opening the radiator cap then will allow the reservoir to be topped off with your water/coolent mix.
Old 01-13-2003, 11:06 AM
dbrown13 dbrown13 is offline
dbrown13 is starting off with a positive reputation.
bleeding air from cooling system fordboy97 1987 - 1996 F150 & Larger F-Series Trucks 6 11-21-2014 09:42 PM
Cooling System RobbD Expedition & Navigator 1 11-22-2013 07:55 PM
Bleeding brakes with AE Headviking 6.0L Power Stroke Diesel 5 07-31-2011 01:27 PM
cooling sysrem bleed valve 02 explorer 4.0 buzzincuzzin Explorer, Sport Trac, Mountaineer & Aviator 1 01-18-2011 07:45 AM
bleeding abs system tboss619 1987 - 1996 F150 & Larger F-Series Trucks 7 12-28-2008 10:22 AM
Tags
95, 99, bleed, bleeder, bleeding, coolant, cooling, f150, f250, ford, navigator, radiator, system, trouble, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
