big door glass installed
fuzies
I used clear silicom on them. Talked to a guy and he showed me his with just the clips and it was wavey looking plus i didn't have much choice cause the inside one that came with the big glass kit didn't have the contour for the hand grab on the 51. Called classic hauler and they said bend it to shape. Well if you do that it would shorten it about 2 inchs. SO what i ended up doing was building the inside piece by useing the felt for the stock glass and cutting the end off and adding a piece from the long ones. you can't really tell i did this. The silicom aplyed to it holds the whole thing in place unlike the clips that holds it every few inchs. So if you useing the big glass plan on getting the stock fuzies as well.
