92 explorer egr valve? - Ford Truck Enthusiasts Forums
Old 01-04-2011, 02:02 PM
strokethis04's Avatar
strokethis04 strokethis04 is offline
strokethis04 is starting off with a positive reputation.
I have a 1992 ford explorer with a 4.0 and It is coming up saying its the egr valve. Does anyone know where the egr valve is? It doesnt idle smoothly either and will cut off if theres no throttle.
thanks.
Old 01-04-2011, 02:46 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
Double check your trouble codes. '92's didn't come with an EGR system. One common mistake is to interpret the 111 pass code ('92's should be outputting 3 digit codes) for a 33 EGR code. If needed, also double check your model year. '92's didn't have EGR systems, but some '93's did.
2004 explorer egr clean out wtroger Explorer, Sport Trac, Mountaineer & Aviator 0 11-30-2012 10:51 AM
Help!- 93 Ford Explorer EGR Valve? dmo757 Ford Inline Six, 200, 250, 4.9L / 300 6 04-03-2012 01:55 PM
2000 Ford Explorer 4.0 (x) engine check engine light on quinttheman Explorer, Sport Trac, Mountaineer & Aviator 5 04-05-2011 10:52 PM
Check engine light egr valve flow problem 1998eddiebauer Explorer, Sport Trac, Mountaineer & Aviator 10 06-22-2005 11:23 PM
Error Code 332. cablemaster Explorer, Sport Trac, Mountaineer & Aviator 12 09-20-2004 06:24 PM
Tags
1991, 1992, 30, 92, diagram, egr, explorer, f250, ford, picture, system, tail, test, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
