Brand new battery draining with 4 days of sitting. - Ford Truck Enthusiasts Forums
Old 01-04-2011, 09:10 AM
tgowers's Avatar
tgowers tgowers is offline
tgowers is starting off with a positive reputation.
I have an 07 f150 5.4L super crew. I came out one morning and the battery was dead. I jumped it, and drove it for a while. Came out the next morning and it was dead again. Had the battery tested... no problems, but changed it anyway with a good NAPA battery. Its been a month now, and i let the truck sit for 4 days, and the thing is dead again. I had autozone put the tester on it, charging system is good, and battery is good. WHY IS MY TRUCK DRAINING THE BATTERY? This must be a common problem. Is there a ground loose somewhere, or a relay that is going out? I have had less problems with my 68 f100.
Thanks guys!
Tony
Old 01-04-2011, 09:31 AM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
No this is not a common problem. You could have a loose wire someplace or your cables could be starting to go. On an older ford I had I actually burned through the cables from some sort of short. It had a similar problem to yours before going but it was also burning up alternators before we saw the damage to the cables and replaced them.
Old 01-04-2011, 11:03 AM
shawn_N's Avatar
shawn_N shawn_N is offline
shawn_N is new and has a neutral reputation at this point.
correct me if im wrong......just because they tested the charging system does not mean the altenator is good right? unless you take it off and take it in to them, i didnt know if they could actually test the diode on the altenator with it still being on.
on my 85 diesel, batterys tested good but would drain the battery. i ended up taking off the positive cable on the battery and tested it with a test light by placing the alligator clip of the test light on the positive terminal on the battery, and the test light to the positive battery cable. light lit up, meaning i had a draw coming from somewhere. ended up being a fuse socket that went to the dome lights. even though when i shut the door the dome light would go off. i just pulled the damn fuse cause it was starting to **** me off having dead batterys.
Old 01-04-2011, 12:27 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
I agree, sounds like a) alternator is bad (Just had to replace mine on my 04), b) you have a drain someplace. Even after you turn the key off, there's still something drawing power. But remember, we have keep alive memories, so you'll have to wait 10 minutes or so after shutting off the truck to see if there is still a load.
Old 01-04-2011, 01:26 PM
ALLDATAdiy INFO ALLDATAdiy INFO is offline
Former Vendor
ALLDATAdiy INFO is starting off with a positive reputation.
Test the alternator first. There is a lot of parasitic draw testing located in ALLDATAdiy if you end up needing to chase down a gremlin.
Old 01-04-2011, 03:15 PM
fordsinair fordsinair is offline
fordsinair is starting off with a positive reputation.
I have the same prob with my 04 supercrew. Sometimes the truck will be dead overnight. After jump starting the truck it won't go dead for another couple months. But it's going to happen at some point...I just don't know when.
Two years ago I actually could not shut my headlights off. I turned switch to off, clicked the dome light roller to off, pulled the fuse but the headlights stayed on. Had to disconnect the battery anytime I shut the truck off. But the truck stopped doing that on it's own. IDK.
Old 01-04-2011, 05:38 PM
AspenGreenMetallic's Avatar
AspenGreenMetallic AspenGreenMetallic is offline
AspenGreenMetallic is starting off with a positive reputation.
I had a problem on a Chev Lumina sedan where the batt would go dead after a night of sitting. Searched all over and tested everything... It came down to a bad switch for the power locks. After pushing the button there were times it was feeding voltage to the lock actuators 24/7.
So there's that possibility...
Old 01-05-2011, 02:10 AM
Interesting. I don't look forward to chasing the E-gremlins in these trucks now a days. LOL.
Old 01-05-2011, 07:17 AM
2002sport 2002sport is offline
2002sport is starting off with a positive reputation.
Hmmm, my truck had a slow start the other morning. Rolled over real slow, I didn't think it was going to crank. That's the only time it did it. The battery and alternator aren't that old.
Old 01-06-2011, 01:18 PM
hcbph hcbph is offline
hcbph is starting off with a positive reputation.
Battery drain
Had a similar thing happen to my T-Bird. After sitting a few days the battery would be drained. Happened to be working OOT for a few months so had to have a mechanic check it out. Wasn't able to find the issue so he swapped a relay into the main power box under the hood so it wasn't energized till the key was on (meaning you don't have interior lights etc till the key is on). Stopped the problem but wasn't the real fix.
After I got back and had a chance to check things out, found that the little trigger on the glovebox light had broken off and the light was staying on 24/7. Fixed that, problem was gone.
Good luck
Old 01-06-2011, 11:35 PM
JoshNHRA JoshNHRA is offline
JoshNHRA is starting off with a positive reputation.
Using a multimeter, disconnect the positive cable from the battery, and place the meter in series with the battery. With everything off, your shoulndt have more the 25-35 milliamps of draw. If you do, find the fuse panal, and start pulling fuses until the draw drops to this spec. You can also remove the positive cable going to the altenator and see if the draw ill go down.
Old 01-07-2011, 12:05 AM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
If you have one of those 120VAC inverters, those things have a minimum standby current of up to a couple hundred milliamps unless they're physically switched off. That'll drain your battery.
Stereo amps that are inadvertently wired to be powered on even if your head unit is off will do it too.
If you have a voltmeter, you can check your alt while the engine is running. Anything less than 13.5V or so is suspicious. But the fact that you could drive around after being jumped says it's good
Old 01-07-2011, 06:47 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Decide on a day to find the energy drain.
Get a clamp on meter. LGT meter;
Sears: Online department store featuring appliances, tools, fitness equipment and more
Place the meter around the positive cable.
Pull then replace fuses one at a time while checking meter for current drop.
See the owners manual for fuse information (pages 275-282)
https://www.fleet.ford.com/maintenan...ls/default.asp
Wait to pull #5 and #21 as these are keep alive circuits
Of course when you find a drop in current draw on a circuit you need to determine the reason for the drain.
Old 02-03-2011, 09:33 PM
tgowers's Avatar
truck was dead again. I had driven it for a couple weeks with no problem, then came out and it was dead. I could hear a clicking noise inside the cab. I found the clicking noise in the behind the back seat of the super crew. I pulled the fuse for the power locks, and the clicking stopped. I am going to drive it like that for a days, and if it is fine then i will try to figure out my next step. Does anyone know if there is a relay or someting behind the back seat?
Old 02-03-2011, 09:46 PM
Fox Fader's Avatar
Fox Fader Fox Fader is offline
Fox Fader is starting off with a positive reputation.
It's obviously a drain on the battery. In a case like my cousins where he went through 3 bad NEW batteries, you could unhook both battery cables and if the battery still goes down you know it's the battery.
Sounds like you found the problem though.
Battery drain csmith30005 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-07-2016 01:55 PM
Battery Help A/Ox4 1999 to 2016 Super Duty 8 05-16-2016 12:27 PM
DRL module issue CrisB_97 1987 - 1996 F150 & Larger F-Series Trucks 2 03-20-2016 09:37 PM
99 F150 4.6 Battery dies over night NUKEHEAD1001 1997 - 2003 F150 9 06-10-2015 07:52 PM
Battery Problems - Need Help Diagnosing goldieWilson 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-22-2015 08:42 PM
Tags
50, batteries, battery, brand, charge, dead, doors, draw, ford, forum, fox, holding, increase, light, mustang, parisitic, shut, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
