Sound System in a 82' F150 Reg. Cab
I am putting a pioneer head unit and four speakers in my truck, also going in are 2 12 inch kicker subwoofers and a sony 600w powered amplifier.
I am trying to decide where to put the amp,either under the seat or on the back wall of the cab. And the best way to do all of the wiring.
If anyone out there has put audio into their truck i would appreciate any input on the subject.
Thanks, stilrich
(P.S.- I know it is sacrilige to change the dash but it was already really messed up anyway)
Thanks, stilrich
The instructions for the amp tell you this, but who follows instructions? I found out the hard way. Make sure you run your RCA cables far away from the power wiring for the amp. It is so tempting to bundle both together and run them down the rocker or under the seat together, but you will really get a lot of noise that way through the speakers. Run the power down the rocker and run the RCA's down the middle over the hump. I would also keep the RCA's away from the truck's power wiring running down the driver's side rocker panel also.
I'd be curious to see your subwoofer placement. I'm not really a sound system guy but I have an Alpine head unit that cleanly goes in the dash, some cheapy 200 watt amp mounted on the cab wall in back (Supercab) and two Alpine type R in the doors. A small sub would be nice but I can't figure anywhere to put it and have it hidden. Space for gear and such in teh cab of a truck is limited as you know, and I'm not willing to have a box laying around taking up space. Hiding under a seat could be possible with some minor floor pan modification, but I would worry about water or mud as every now and again I go deep enough to get some in the cab.
What about taking out the ash tray and mounting it underneath there? I put one of my speakers there, and I can't even see it!
Subs are like TV antennas. Yes they make small ones, but the ones that work the best are the biggest ugliest ones you can get.
You will be disappointed in a small subwoofer, if there is such a thing. The problem is the low frequencies have a long wavelength. So larger diameter speakers with larger boxes are more effcient in reproducing the longer lower frequencies.
cadunkle, I would check ebay. there are a lot of custom enclosures out there that are made for extended cab trucks. At my local tinting\car audio shop they have a floor enclosure made from a thick ABS style plastic that is used for boats. Maybe something along those lines would work.
As far as mounting under the ashtray, that could possibly work for an eight inch sub, but i think you could get a lot of dashboard rattle and distortion from the electrical components in the dash.
