Anybody running this kit on their F350. Debating to use this kit or replace my worn X codes with new ones and Bilsteins. Thanks.
How long have you had your X codes? My driver side stockers are sagging after 106,xxx miles and I am getting ready to pull the trigger on X codes. Are you plowing with them?
I just turned 90,000 and yes it was plowed with before I bought it. And no I was not going to use the pro comp shocks, Iwas going to get correctly valved bilstiens.
I still have the original on my truck. I'll probably put a new one on when i do the springs. I may go with a pair of X codes from Deaver, just need to compare prices from them and the ford dealer.
