E4OD tranny with carburetor ? - Ford Truck Enthusiasts Forums
Old 01-03-2011, 07:42 PM
papajunk papajunk is offline
papajunk is starting off with a positive reputation.
Can I use an E4OD tranny with a carbureted engine ('91 F-250) ?
Old 01-03-2011, 07:52 PM
lablue96 lablue96 is offline
lablue96 is starting off with a positive reputation.
yes you could, you would have to run a stand alone controller for it though since it's electronic. if i remember i think baoman engineering had one....
Old 01-03-2011, 08:03 PM
Thanks, that's what I was afraid of. I'd been told by someone that as long as I left the tranny connected to the computer it would be OK with a carb., no mention of a controller. Do you know what the tranny will (or won't) do if I just use a carb. with nothing else added ? Thanks for the help !
Old 01-03-2011, 09:47 PM
i'm not sure about that, but i've never done anything like that. the way i understand it is that the oem computer was designed to run the engine and tranny as one, if it's not getting a signal from the carbed engine i believe it will no let the tranny funtion properly, it may be able to but i doubt it.
i believe the shift points in the transmission are done through the pcm, as well as the tc lock up, wich are both programmed with the engine rpm and load.
Old 01-03-2011, 09:48 PM
L. Ward's Avatar
L. Ward L. Ward is offline
L. Ward has a good reputation on FTE.L. Ward has a good reputation on FTE.
I don't know if anyone here has tried it, but I suppose it would be possible to run a tps on the carb, and then let the ecm control the tranny.... may require some other tinkering to get it to work with the signals from the carbed motor. Otherwise a Baumann controller will run the E4OD. Without a controller or wiring in a tps, you would need a C6 or AOD
Tranny is Luke Guihan 1978 - 1996 Big Bronco 3 05-29-2016 03:23 PM
Tranny...which is stronger? codyingersoll123 Clutch, Transmission, Differential, Axle & Transfer Case 10 07-16-2015 04:18 PM
E4OD Build mongo12 1994.5 - 1997 7.3L Power Stroke Diesel 6 03-11-2010 01:06 AM
Opinions on the E4OD johnboggs21 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 44 06-08-2009 01:53 AM
2wd e4od tranny conversion to 4wd fordreeves 1987 - 1996 F150 & Larger F-Series Trucks 0 08-07-2004 03:22 AM
Tags
460, carb, carburated, carbureted, carburetor, controller, e40d, e4od, engine, ford, motor, tps, transmission, wells, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
