Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1967 - 1972 F-100 & Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 01-03-2011, 05:47 PM
Andy_Bracy Andy_Bracy is offline
Garage is empty, add now
Andy_Bracy is starting off with a positive reputation.
670 S.A. lean/no secondaries
lookin for some advice on my holley 670 street avenger.. 67 ford, 360 fe. been sittin for about 2 years performed a tune up on it changed plugs, cap, rotor etc. well i removed the carb and rebuilt/cleaned got it back together and noticed it was running extremely lean. went up 2 jet sizes 3 times for a total of 6 sizes, no difference whatsoever, realized the motorcraft plugs were alot hotter than champions so put champions back in and went back down on jets.. then again realized secondaries are not opening (not sure if they ever were) but was told that wouldnt have an effect on the lean condition, so took carb apart once again didnt seem to find anything wrong but did notice one thing theres no check ball in the secondary housing but there is a brass plug on top?? any help or advice would be great thanks!
  #2 (permalink)
Old 01-03-2011, 06:12 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Well, you won't see the secondaries open while revving it in neutral, they are opened by vacuum once you have used all the available flow from the primaries.
I think the check ball is only there in conjunction with an accelerator pump, since it's on the secondaries the passage should be blocked.
What Motorcraft plugs were you running? I like to run Autolite 45s in my 4BBL 360.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
  #3 (permalink)
Old 01-03-2011, 06:20 PM
yea i did the paperclip test (zip tie worked better) im not sure the number m/cs but they were oem replacement
Tags
avenger, ball, check, lean, secondaries, secondary, street
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
