Ford System 4 Security System - Reset FYI - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-03-2011, 03:03 PM
Boat Tug Boat Tug is offline
Boat Tug is gaining momentum as a positive member of FTE.
I have a 2000 Expi that has the Ford System 4 Security System installed by the Dealer when new.
I've had this vehicle since 2003 as 2nd owner and recently it needed a jump start. After that the Sys 4 Alarm went crazy and I was only able to start the car after pushing the Emergency Override Button.
http://www.ford-trucks.com/forums/90...m-removal.html
I have the Owner's Guide for this system but that does not explain how to re-set the system back to default.
I found the answer here:
http://www.f150online.com/forums/lig...ystem-4-a.html
I followed his step-by-step procedure and it worked! Problem solved for me.
I have copied Sycoholic's 're-initialize' procedure here in case someone else has this trouble. Just passing along this info as a little payback for the help the Forum has been to me.
Re-initialize Ford System 3 (or 4) Alarm System:
<hr style="color: rgb(255, 255, 255); background-color: rgb(255, 255, 255);" size="1">Disconnect the battery. Wait 2 minutes for the module to lose all traces of voltage.
Turn the ignition key to the RUN position.
Reconnect the battery.
Shut the key OFF and press LOCK on the drivers door switch.
It's called reinitializing the alarm.
Old 01-03-2011, 04:41 PM
penzly penzly is offline
penzly is starting off with a positive reputation.
Thank you so much for this post! I have had the same or similar alarm in my 98 that I bought at auction in 2000. I have been afraid of it since then because I have no docs at all. A few times I have inquired at the dealers only to be told they knew nothing of it. So I religiously watch the blinking light/button on the dash and hope it never fails. I also have a switch in the glovebox, but the wires are disconnected. Any ideas on what that might be?
Old 01-03-2011, 06:43 PM
Quote:
No, my 2000 Expi EB 4WD does not have a switch in the glovebox. It has a switch on the firewall, under the glovebox, for the air suspension.
This alarm stuff is all a mystery to me, I'm learning as I go.
With all the different modes and the starter bypass it is difficult to understand without a Service Manual or Installation Manual, which I don't have.
I do have the Owner's Guide which describes the Valet Button blinking lights and the various 'chirps' and I guess I'm lucky to have that. Maybe posting the 8 page OG might help someone, I'll try and figure how to do that.
If I run across something that pertains to this issue I'll post here, sorry I can't be more help.
Old 04-06-2012, 05:25 AM
MarauderV8 MarauderV8 is offline
MarauderV8 is starting off with a positive reputation.
short question, at my Marauder i installed the system 4!
when i armed the system,, i can hear 2 chirps. thats normal. but the chirps have a gap of ca. 3 seconds. is this normal? the most systems which i know has a gap from 1 second maximum
Old 04-06-2012, 11:40 PM
I reviewed my Users Guide and all it says is 'two quick chirps of the siren', which does not sound like they mean 3 seconds apart.
Mine has the chirps about one second apart.
How does it work otherwise, the alarm go off when it should?
Does the Valet button show the correct blinking patterns?
Old 04-07-2012, 02:31 AM
yes, everything else works great. if i lock the car, the blinking rate is approx. every second. if i open a door with open window and the system is armed, the siren sounding the alarm. if the system is armed and i shake the car, i can hear a short chirp. during armed the system, the flashers blink two times. during disarming the blink one times.
The only different is, i donīt connect the STARTER INTERRUPT feature and the VEHICLE HORN CONNECTION!!!!!!!
Old 04-08-2012, 02:56 PM
Well, you may have answered your own question.
The alarm circuits are not seeing what they are supposed to see, possibly making the system do abnormal responses.
Two choices now, install it completely and see how it performs.
Or, if you are happy with it as an adequate alarm, use it this way.
Old 04-09-2012, 02:39 AM
okay, iīll connect the starter in the next days. let you know the result
Old 04-10-2012, 10:37 AM
correction, itīs not 3 seconds, approx. only one, but for me, i guess, the time is even so too long, or not?
IMG_0396.MOV - YouTube
Old 04-14-2012, 04:38 PM
today, i connect the ignition with the alarm system.
still the same sluggish chirp. is that normal or not??
Old 04-14-2012, 05:24 PM
I'm not an alarm expert, just a user like you.
I've already expressed all I know about these alarm systems.
My User's Guide says 'two quick chirps of the siren'.
My Expeditions 'chirps' (and lights) are closer together than shown in your video.
If anyone else knows more about this subject please add to our knowledge.
Old 11-27-2012, 12:12 AM
mounted the same unit in a F150, itīs the same as in the MM. Seems, itīs normal
Old 03-09-2013, 02:38 PM
since two days, if the car is closed and the alarm is armed, the system give an fail alarm. my solution in this moment is not to lock the car. who can explain me a trouble shooting for the system?
Old 03-10-2013, 03:20 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Maybe one of the door switches is hanging up.
Old 03-11-2013, 11:01 PM
Quote:
how can i find it out?
What kind of starter for 02 7.3? ScubaTX 1999 - 2003 7.3L Power Stroke Diesel 13 03-25-2015 11:16 AM
My first Diesel Truck on order Troy_C 1999 to 2016 Super Duty 33 11-15-2013 06:55 AM
What conditioner do you use on dash's painted surfaces? DallasSuperCrew 2004 - 2008 F150 1 04-02-2013 09:28 AM
Dual Liner now available in Canada!!! Dual Liner Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners 2 12-20-2010 08:03 AM
Tire Size Help for 2wd F250 1974 camper special 74f250scs2wd 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-02-2010 07:37 PM
Tags
1997, 2007, 4, 96, f150, ford, or, package, reset, resetting, security, system, system3system4, truck, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
