How to identify an FMX
on
If it's cast iron, and is a 3-speed auto, that is an FMX. You did not say what year truck this was in tho. Originally, the FMX was called Cruise-O-Matic. Later, "Cruise-O-Matic" was used as a marketing term for ALL Ford 3-speed automatics and the original Cruise-O-Matic became the FMX. This was in the mid-60s I think.
One word of caution - on the original Cruise-O-Matic, the selector dial had a white dot and a green dot where D and 2 would normally go in a traditional configuration. The white dot is "D2" and the green dot is "D1". In D2, the trans will start in 2nd and upshift to 3rd. If you want to start out in 1st, you need to put the selector to D1 (green dot). What this means is that if you want your trans to work the way most all other 3-speed auto transmissions work in "D" then you must go to the green dot, which is where most transmissions would have you in 2nd. Takes a little getting used to.
sullyda1
06-16-2020 01:04 PM
robert_allen
06-28-2018 02:51 PM
cr500monster
05-04-2013 03:16 PM
fastredford
13
05-04-2010 08:33 PM
